Low fuel pressure light that light up around 12 psi plus psi?
- Replies 12
- Views 4k
Mopar1973Man 2 posts
KATOOM 2 posts
TFaoro 1 post
leathermaneod 1 post
Popular Days
The ISSPRO gauges have a light that you can program to come on at any FP that you would like. But if you are throwing money at something, I wouldn't mess around with just a light, I would certainly p
Just buy the ISSPro EV2 gauge also buy the Relay Kit. Then just program the relay to trigger at the pressure you want. I want to hook into the cluster and hit the CHECK GAGE light and trigger the stoc
Op here...Thanks for the info and replies. I sure wish I'd known of those fuel pressure gauges with warning lights before I bought one last month . Also found this one. http://www.
Anybody know of any low fuel pressure light that lights up around 12 psi or little bit higher?
I have an Airdog fuel pump. Already have an BD and Airdog low pressure light , but they light up when fuel pressure is much to low in my opinion.
In process of installing a fuel pressure gauge but would also like light that goes off around 12 psi or little bit more.
Thanks
Edited by 015point9
