Need a new set more than likely. Going to Getty mine bench tested. But need good information beforehand just in case.
Shed your knowledge on injectors on me. Who to go with and why.
I've heard a bit but need set straight on some things. My DAP set is less than 40k on me and at least one of them is bad. I don't like that idea...
  • Replies 145
  • Views 23k
    There was a TSB for early model truck for change out of cross over tubes because it is easy to crush or distort the crossover tubes.   Another thought is that it's possible the pooled fuel i
  • Normally teflon would bother me. If you just put the tape on the threads for the nuts to screw on then it is outside of the fuel system. The threads on those nuts do not seal anything. They allow the
    Bad injector o-ring will leak fuel into the oil just as @dripley said. Bad crossover o-ring will leak fuel out on the intake manifold. It will not leak fuel into the oil. Bad copper washer w
It's just getting old running through the gambit of vendors having to do things twice when it should be done right the first time.
...that's not bashing Eric at VP. Im just getting tired of it. It can be bad enough fixing the truck but then trying to fix it with inadequate parts sucks even more.
Edited by hex0rz
8 hours ago, Mopar1973Man said:
I thought you bought the Injectors from DAP (Jacob)???
IIRC that is why we are discussing options for replacement due to his failed injector and subsequent following issues.  I am by no means bashing anyone....
@hex0rz eager to hear how the new set pans out and thats through the vendor I was considering, I hope all goes well.
If I get a set of rebuilt injectors should they be flow matched and pop tested?  Then if a shop rebuilds them shouldn't they already be flow matched and pop tested, Vulcan VP injectors are they pop tested and flow matched?
I only ask because for me to accomplish flow matching and pop testing would cost me a 3 hour drive and overpriced service that bills by the hour at 110 per hour
That would be a question for who ever you would buy from. Then you have to have the trust that they really do it. I am running a set of DAP rv275's. They have about 140k on them. They have always worked fine but I think they are getting a little worn and one seems to be firing weakly. Not a miss but does generate a little vibration at idle sometimes. More like firing with a partial fuel burn at times. Othe times like today it purred like a tiger at idle. I am in the market for a new set.
I'll keep you posted as to how the new set differs from these currently in the truck.
Still waiting for them to get here though... guess I'm gonna need to call for a tracking number. Hope i can get them in next week.
DAP  supposedly did pop testing and flow match. They just did it initially with an injector with the wrong nozzle!
I bought new RV275s from  Vulcan.I beleive he said they were Bosch. 5,000 miles on them and I am very happy with them. 1mpg bump in mileage loaded or empty. Nice boost in power also.
Got them yesterday. Going to put them in this weekend!
There was a nut included, any idea?
I think you're supposed to put it behind the steering wheel, sorry just kidding have no idea
Possibly a nut to use to pull the old injectors with the valve cover bolt, but i have never needed a nut.
That's more likely the injector retaining nut. You can see them half buried around each injector on your old ones.
Make sure you put small amount of grease on ea tip (under the copper sealing washer) so you won't loose the washer when you drop them in place.
To pull the old ones just cut 1'' pcv pipe the right length with a washer on top and screw right size threaded nut down on top. I found an old lug nut that fit perfect and pulls them out very nicely. Thanks to Mike this suggestion was great cause you can't return malled up injectors been chewed with pliers. Don't try turning them they need to come straight out.
I prefer to use a vc bolt or intake horn bolt. Screw it in a few threads and then wiggle or use a pry bar to pop them out. Make sure to pull the tubes far enough away lol. That one was a bit puzzling for 10 or 15min.
I have seen some install kits that include a nut to pull the crossover tubes with, thats what i am thinking it is. They will just pop out with a screw driver. I also used a bolt in the injector and pried the injectors out. They just popped right out.
 When you install the new be sure and snug up the injector lines to the tubes and then tighten the injector hold downs. Like to drove my self crazy trying stop leaks until I did that. It lets seat properly.
....well this won't be my first rodeo!
The nut appears to be sized for just that, crossover tube removal.
I have only done mine once but never saw anything telling me to do that. So technically I have done mine twice learning that one. I just hope this solves your issues. You have had quite a few for this one problem.
Biggest one is i want my fuel mileage back!!!
Got the injectors swapped out with rv275s. New injector o rings made the injectors crazy hard to get in but they're in!
Got or fired over eventually and she smoked a ton at idle! Let it continue running while i cleaned up. Looked like it went away so i took it for a test drive. Couldn't go any faster than 15 but it performed better and was much more responsive.
After i got back to the house i shut the truck off and then restarted it. Got that immediate turn over back again!
Needless to say, DAP will be getting a call and getting an earful for the sub par workmanship!!!
Alright someone remind me, because for the life of me, i cannot get my injector lines to seal to the crossover tubes! I've tried everything i can think of to get them to seal and they are still weeping fuel!
I'm going to pull my hair out...
I wonder, temporarily could i Teflon tape the nuts until i figure out a solution?
It's coming out between the head and the nut on the threads. I even torqued the line nuts to 28 ft pound with a crow foot.
