Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 335.2k
  • Quadzilla Power
    Quadzilla Power
then use the profile you are using.  Do you have a windows computer to update the box under the hood?
Yes but I couldn't find the info on where/how to update
that thread covers it with a video walk through
Hey fellas, long time no talk, truck has been doing pretty well besides my original s366 taking a crap and a broken output shaft.
When the turbo went out, we went with the s366sxe and i finally found out that im running 6x.018 injectors...
Havent done anything with my tune that i showed u the dyno sheet on, but on hard pulls the truck is starting to sound choppy.  Almost like its popping off the rev limiter.  I dont wanna add much timing because im already pushing my luck as is with stock headbolts and factory gasket.  The smoke is there, its not lean by any means.  Since the new charger is boosting more, is it affecting the parameters of the v2?  Im boosting 60psi...thanks for the help and input in advance
if you are getting popping you should dial back the timing.  I have no idea when the last time you flashed was, but some code improvements have been made to make things smoother.
Flash the latest, update your app and select the 1998-2002 v2.5 profile and report back.
On 22/07/2017 at 8:57 PM, Dieselfuture said:
I think I may need some help with tuning. I now have 62/67/12 made out of hx35/40 and 75hp 8 hole injectors. It's definitely laggy compared to my hx35 and 60hp I had. But I did little bit of turning and it got a little better. My starting point is 80 on canbus with 3 for increase. http://www.rapidtables.com/calc/math/exponential-growth-calculator.htm
My biggest problem or maybe not a problem, is that before I changed turbo from hx35 to current l used to be able hit 45 psi (passed 35 probably nothing but hot air ) pretty quick, and now I'm struggling to hit 25. Max I hit for psi is 30 with canbus maxed and pump stretch at 1200. Another thing is cursing at 60mph my canbus was maybe at 600 and now it's at least a 1000 and boost went from 7-8 to 3-4. Is it just the nature of bigger turbos. Does anyone else has a similar set up that can post their tunes. Daily, economy, tow etc.
Edit:
Had a boost leak on new turbo, it's much better now on lag and canbus is down to 7-800 from 1-1100 when cruising. Still trying to figure things out.
Diesel future I got about the same mods I just uploaded the time that I Daily it's got good throttle response and pretty smoke free asking as u are good with the throttle lol
disclaimer I never go wide open throttle from a dead stop or slam on the throttle so use at ur own risk
Edited by Silverdodge
well heres what i have. Most will need a little tweeking. lmk if you see anything you would change and i will also mention things i might need help with
DAILY this one the timing is still a tad to advanced crusing i think. about 21.5 at 60mph 3.55 gears nv4500 overall goal is to get best mileage with but still be able to hammer down and pass a car safely honestly a tad less smoke and lower egt wouldn't hurt my feelings but also can't really start my canbus any lower. Already a little lower than I like. Truck surges under slow speed low rpm excel, like coasting around corner in 3rd at idle and trying to speed up, seems like to low of fuel or something Idk
TUNE PARAMETERS
Number of Power levels: 8
RPM Limit:3700
VALET MODE PARAMETERS
Maximum Valet Mode Power: 60
PUMP TAP PARAMETERS
Maximum Fuel Stretch:1200
TPS Pump Maximum: 100
TPS Pump Minimum:25
Pump Low Boost Scale PSI  15
Boost Scaling: 40
TIMING PARAMETERS
Fuel Load Timing:2
Low PSI Timing Reduct:3
RPM TIMING MAX
1500 RPM:17.8
2000 RPM:20
2500 RPM:24
3000 RPM:27
Max:28
BOOST LEVEL FUELING - CAN BUS
0 PSI:69
1 PSI:70
2 PSI:71
3 PSI:72
4 PSI:73
5 PSI:74
6 PSI:75
7 PSI:76
8 PSI:77
9 PSI:78
10 PSI:79
11 PSI:80
12 PSI:82
13 PSI:83
14 PSI:84
15 PSI:85
16 PSI:86
18 PSI:89
20 PSI:92
22 PSI:95
24 PSI:98
26 PSI:101
28 PSI:104
30 PSI:107
TOW. havent really used much but will be tomorrow anything that sticks out lmk
TUNE PARAMETERS
Number of Power levels: 6
RPM Limit:3400
Maximum Valet Mode Power:80
PUMP TAP PARAMETERS
TPS Pump Minimum:25
Pump Low Boost Scale PSI20
Boost Scaling:40
TIMING PARAMETERS
Fuel Load Timing:2
Light Throttle Timing Load Limit:25
RPM TIMING MAX
1500 RPM:15
2000 RPM:17
2500 RPM:22
3000 RPM:24.5
Max:26
0 PSI:79
1 PSI:80
2 PSI:81
3 PSI:82
4 PSI:83
5 PSI:84
6 PSI:85
7 PSI:86
8 PSI:87
9 PSI:88
10 PSI:89
11 PSI:90
12 PSI:91
13 PSI:92
14 PSI:93
15 PSI:94
16 PSI:96
18 PSI:99
20 PSI:102
22 PSI:102
24 PSI:104
26 PSI:106
28 PSI:108
30 PSI:110
GO FAST a little more power wouldnt hurt anything here
TUNE PARAMETERS
RPM Limit:3700
Maximum Valet Mode Power: 80
PUMP TAP PARAMETERS
Maximum Fuel Stretch: 1800
TPS Pump Maximum: 70
TPS Pump Minimum:0
Minimum Pump Tap Fueling Percentage:25
Pump Low Boost Scale PSI10
Boost Scaling:40
TIMING PARAMETERS
Fuel Load Timing2:
Light Throttle Timing Adv:3
Light Throttle Timing Load Limit: 15
RPM TIMING MAX
1500 RPM:16
2000 RPM:19
2500 RPM:23
3000 RPM:26
Max:28
0 PSI:90
1 PSI:92
2 PSI:94
3 PSI:96
4 PSI:98
5 PSI:100
6 PSI:102
7 PSI:104
8 PSI:106
9 PSI:108
10 PSI:110
11 PSI:110
12 PSI:112
13 PSI:114
14 PSI:116
15 PSI:117
16 PSI:119
18 PSI:124
20 PSI:126
22 PSI:131
24 PSI:136
26 PSI:142
28 PSI:146
30 PSI:150
Edited by Dodgeih
Just went to check on some downloads and the Adrenaline has a v2.6.1 update released on Wednesday for Standard_fuel if y'all are trying to keep your box up to date
@Me78569 Do you happen to have the new timing parameters on the default tune since a few of those parameters have been replaced with *  ?
Edited by Cronus577
4 minutes ago, Dieselfuture said:
I'm guessing this 2.6.1. Is so quad doesn't freeze when changing levels
Hopefully but probably not. The only thing the changelog says is:
"Increased default fuel maps fueling for added fuel for stock vehicles. "
2* I think and 30% load
Really, like the description says, the only update is to the default power levels on the CAN  bus. Using the the latest 2.5 tunes (2.5.2) and with custom tuning you literally won't see anything different.
The reason for the rev of the number to 2.6.x is because we are thinking of adding KPH for our friends in the Great White North to the vehicle profile as an additional sensor and any modification to the vehicle profile needs a revision update.
About the freezing, that should come with the latest version of the app. I updated the .apk link here for that too.
Here is another link to it:
http://quadzillatech.com/TunesDownloads/AndroidApp/IQUAD_Android_app-release(1.9.40(56)).apk
To our iPhone using friends. Do you see a need to see the progress bar? or is the spinning wheel good enough for y'all?
I say do it for them too. It's nice to see where it's at during the process of updating the module.
If you're going to do metric gauges might as well do the full deal. I would just make a setting that is american or metric and just toggle. Then all the plugin modules will display metric or american.
2 hours ago, Quadzilla Power said:
While we are adding the KPH, any other parameters that you want to see options for in metric? kPa for the boost or Centigrade for the ECT and EGT perhaps (I'm not sure this one is feasible frankly)?
I'd like to chime in as one of the fellas in the great white north. A lot of us, especially in the prairie provinces, are kind of caught between metric and imperial for some things. I use a little bit of both. KM/H would be awesome, however ECT, Boost, EGT I would always keep in Imperial. So one switch that changes all units at the same time for me wouldn't be feasible for me personally. I'm not sure how everyone else feels though.
Personally I think that things like fixing the app freezing when change levels and random failures of the app are more important than this or maybe other changes. and addding the "name" is current selected tune somewhere on the gauge screen would be amazing
Have you downloaded the Beta version and tested it for freezing? I really think that it fixes most of the issues that caused the "freezing".
If it doesn't fix it for you let me know.
I like the idea of having a title bar with the "name" of the currently selected tune somewhere on the screen. I will have to look into it. As it displaces stuff on the screen, it may cause all sorts of headaches and issues and might be cost prohibitive.
-thanks again,
-thanks again,
I will try that download thanks! It wouldn't have to be big and bold. Maybe could even be a parameter that you could choose to watch? I think it would be helpful and nice to see thanks
It's not on the gauge screen, but if you just click the custom tune menu, the current loaded tune is check-marked.
