- Replies 13
- Views 4.8k
notlimah 3 posts
Mopar1973Man 2 posts
dripley 2 posts
015point9 2 posts
Popular Days
In my opinion its best to modify your fuel basket or just buy one that's already done from vulcan (costed me about $70 to do it myself, buy a draw straw 5 from vulcan and make all of the mods to baske
Two Fuel pick up in the same tank that feed the same pump will not work. The first pick up to run dry will suck air and cause the pump to loose it's prime. They would have to be isolated by having t
Looking for a working around solution for 1/4 tank issues.
Fuel is thru a sump that is at very rear of tank. When going down step hill I run out of fuel. (Actually when wife stops at mail box on our step driveway) Now she is scarred to death she'll be going downhill and run out of fuel and no power steering.
I would like to install something that has more of "supply" of fuel than the small filters on airdog. Thinking about a filter housing without the filter installed, which would be just a space for more fuel than the airdog filters provide. I'm thinking about something about the 1/2 gallon size.
Question...this should work if I install post airdog filters right? Or if I start sucking air anywhere in (pre or post filter ) I'm sol?
I'm under the impression the pump will keep pushing fuel forward toward VP under pressure.
(I know... keep tank on 1/2 or better and I won't have fuel issues...but that's not always on my mind.)
Edited by 015point9
readability
