Installed a Nations alternator - results
  • Popular Post
I try to be proactive towards the maintenance of my truck rather than reactive.....
Knowing that the OEM Bosch alternator had almost 120k miles on it, I felt that not only was it probably going to give me DC troubles in the near future but I was also sure that I was most likely experiencing some AC issues as well, especially during the cold morning and hot summer weather.
Why I say that....?  I've tested my AC voltage before during the summer and it was within "spec", but still I thought the readings were higher than I'd like.  So I recently tested again before installing the Nations unit just to confirm and what I got was about .044 during idle.  Yes thats acceptable but also understanding that its 35* outside and the engines warm enough that the grids are not cycling, I felt that there was nowhere for the AC readings to go but up.  Meaning, as the weather gets warmer and/or the alternator is powering more accessories, the AC voltage reading will only increase.
Alternators will produce the least amount of AC at idle with little to no electronics running.  But ramp the throttle up to around 2000 - 2500 RPM, turning on every electrical component and the readings will always increase as the diodes work at converting.  I saw that the last time I tested it in the summer so I felt I'm justified in replacing before problems arise.  Plus I noticed a considerable amount of red brush dust on the tensioner pulley (seen in the picture) which reassured me that it was getting old.
So I've decided to replace it.  Exploring my options, they are as usual.....  To either rebuild my current one, get an over the counter "lifetime warranty" parts store unit and hope for the best, or look for one of the few high dollar units available out there in the aftermarket world.  Well given money is always a variable, I chose to go with the Nations unit I've heard good things about.  Not only are they priced what I consider to be reasonable for what you get but they're also American made.  Plus if I have trouble, I'd rather deal with Nations than deal with either Autozone, NAPA, O'Reilly, etc... and risk delicate electronics on this truck.  Yes, I could have had it rebuilt but I'd still have an alternator that may or may not generate more AC than I'd like because of the windings and diode count, but I'm sure I'd probably have battle with the small shop explaining what I want and why, since most places are more concerned with DC output rather than what the AC voltage readings are.
This is the one I opted for.  180 amp, hairpin wound, 12 diodes, and uses the stock pulled size. http://www.nationsstarteralternator.com/180-Amp-HP-High-Output-Alternator-for-2000-Dodge-p/13874-180-hp.htm
Just to be clear.....what I was experiencing with the OEM alternator was the norm and had been this way for years.  That said, typically the volt gauge in the cold mornings would do as described:
Turn key ON, gauge drops to the lower portion of the "normal" range.
Start engine when WTS light turns off.
Gauge immediately drops back down to the lower portion of normal as the grid cycles on again.
Gauge starts to climb rapidly as the grid cycles off.
Seconds later the grid cycles on again and the gauge dips down to the lower portion of normal.
This back and forth takes places for a few minutes depending on the ambient temperature.  And when it does, the engine clearly lets me know that the grids are cycling by either making the tell-tale noise of loading down from the alternator drag, and/or I can get a slight momentary idle lope only to immediately regain regular idle.
The lights dim considerably as well and the volt gauge generally reaches just a tick over 14 volts when its completed the event or I drive off.
Well after the install of the Nations unit this is what takes place:
Gauge does NOT drop back down to the lower portion of normal as the grid cycles on again, but rather remains up around 14 volts.
Gauge moves a tad higher than 14 volts as the grid cycles off.
Seconds later the grid cycles on again and the gauge drops no lower than 14 volts.
As before, this back and forth takes places for a few minutes depending on the ambient temperature.  But this time the engine does NOT react the same but rather hardly lets me know that the grids are cycling.  There is no tell-tale noise of loading down from the alternator drag and I seemingly had no slight momentary lope during that moment either.
I cant say about the lighting at this point because I havent driven it during the night since the new alternator was installed.  But I'm going to guess that they will not dim nearly as much given that the alternator appears to be cranking out more amperage during idle while creating less load on the engine.  I also tested the AC voltage as soon as I installed the Nations unit, while during the same cold weather, and saw about .020.  I'll be testing it some more as the weather warms too.
Lastly, I would say that of the few times I've driven it since the install the engine has slightly better manners during the cold weather.  This only further supports the understanding that these trucks are VERY susceptible to electronic anomalies and the alternators are absolutely something to pay attention to. :thumbup2:
Edited by KATOOM
  • Replies 69
  • Views 20.4k
  • The cable is actually black with a tan tracer and comes from the splice on the drivers side of the motor. The is the ECM ground plus about 4 others. WT's ground mod is the way to go. It shortens all t
  • Technically it affects every electrical component in the truck. The most vital parts are the ones it affects most though. (ECM, PCM, PSG)
  • Any DC powered electrical device is not going to like being blasted by AC power.   Since our entire electrical system is DC 12v everything will get damaged given enough time.
I will be following this since I am the owner of my third lifetime warranty alternator. Bought the first one about 7 or 8 years ago. I do test for ac voltage but no where near as often as I should. I have been eyeing the Nations from reviews here. Tis is just another plus for them.
 I am curious why you went with the oem pulley versus the smaller one? Not critiquing your choice just curious.
So I had a chance to drive it tonight.....  The lights did dim when the grids cycled but nothing like before.  Matter of fact, the volt gauge dipped initially upon start up when the grids cycled, but then remained again up towards 14 volts again.  All in all I'm happy.
And dripley, Nations uses the OEM size pulley on this alternator whereas other aftermarket high dollar units will use a smaller pulley on theirs in order to spin it faster.  The problem with that is you then have to get a shorter belt to fit the serpentine system.  Not what I wanted to do.
Edited by KATOOM
 looks like a good quality alternator, the only thing I noticed is the add says 5.9 V8 and diodes are 40 amp instead of 60 but there's more of them, other than that looks like well built.
I cant defend their website since its loaded with errors and will have you second guessing what you're looking at.  But yes, this is the correct part number.
And yes, instead of 6 diodes they use 12. :thumbup2:
Good to not have the smaller pulley since a faster spin will generate heat and reduce its efficiency. Very good report Katoom.
Make sure you hooked it up right Bud... we don't want to have to start calling you Kaboom .
Just kidding
BTW, guys in Redding, I noticed ,keep their tucks like they just came off the showroom... where's a pic of your truck?
Gotta maintain a certain level of anonymity for all my fans..... :whistle:
 Got to hide the lear jet on your own private airport next to your truck?:poke:
Next time my NAPA alternator dies I'm heading this direction. Nice mild boost of power, no modifications to the electrical, direct bolt in and wire up alternator. Bit more money but a very nice upgrade.
KATOOM would you be willing to create a write up of this for the site?
I noticed on their description that it has an internal voltage regulator. How does that interact with the PCM voltage regulator? A question from the electrically challenged.
Maybe I'm not fully understanding what you're referring to, but I'm happy to do whatever you need. :thumbup2:
As I mentioned before, I cant defend their website as its chalked full of errors. :doh:
Just like Nick said just go over to the 2nd Gen area and create a article with all the information you provided here which you can more or less copy right over to the article page. Just makes it much easier for other to spot the alternator article. Not to mention I'll be more prone to using the link from the article data on other sites as needed.
I'm having real bad TC lock up issues out of left field. This one says 01-02 did the plugs change or will it work on my 99?
You'd have to call them because their website is seriously lacking accuracy.....  But I'm sure they offer one for your year.
yeah my paycheck should be hitting the account tonight. I have an ebay special alternator atm and I pulled the fuse issue solved. It is violently locking and unlocking to the point that I have been driving around in 2nd gear to avoid the whip-lash lol.I gave them a call.
part# 13766 for 1999 cummins 180 amp I just got mine ordered.
Edited by Jolsen
Alternator installed. I had to make the ground loop hole bigger to fit over the bigger stud on the new alternator. but otherwise when on great.:woot: My TC issue seems to be fixed now. I will be taking the truck on a 100 mile trip tomorrow morning to town to get the tabs for the motorcycle and drop the tax paperwork off.
Hope it works out for you. :thumbup2:
TC didn't act up one bit. funny part is I talked to several shops and they all wanted to put a noise filter on. I said it didnt need it for 18 years I want to find the real issue not mask it...
@ who knows the answer.
So this AC noise effects torque converter directly, or does it affect ECM PCM and then it affects torque converter ? Just curious
