Summer refresh thread
- Replies 19
- Views 4.1k
notlimah 5 posts
Mopar1973Man 4 posts
jlbayes 2 posts
NorthernDodge 2 posts
@NorthernDodge ha ha, love the profile photo. Don't get me started on this subject. Around where I live, it helps to spot retards on the road. No offense to anyone that is using it for intended purpos
1 I did my front a few months ago and got them off of Rock Auto.Bought the rotors and pads for just over $100 along with new seal kits for the calipers. Forget what the total was. I am not brand spec
Well with the weather and day light times slowly moving towards towards warmer and longer, I'm getting together a list of things (mainly common preventative maintenance stuff) thing I'd like to get done. I have some questions regarding each so help me out!
1. Brakes: I'm pretty sure the PO got them done (probably just pads) just before I bought it but I'd like to redo the rotors and pads. Anything special here I should be looking at brand wise or pad material? Geno's sells hawk pads, are they any good?
2. Ball Joints: I've read through @Me78569 thread on his quest to find some, so were the spicer ones from Dennys able to get the job done?
3. Hub Bearing: should I just do these since I'll be taking the rotor off? I can't seem to figure out if the 02's are the ones that are a pain to get apart or if it's the 2000 and older trucks?
4. Starter: I'll probably go with a rebuild kit from LarryB's but could anyone tell me how involved this is?
5. Heater Core: Pretty obvious this winter that my core is not pumping out enough heat, even when fully warm so I plan on getting in there and replacing it. Any suggestions on heater cores? I've heard pros and cons for both the ones with the swivel ends and the ones that are completely rigid. I'll probably try and do a dash replacement at this time too since I'll basically have it all apart.
6. Other miscellaneous stuff I'd like to do are airbags, shocks and springs, and ideally smaller tires.
I'll leave it at this for now. Thanks in advance!
Edited by notlimah
