Torque Converter/Turbo size
Starting a new thread so we don't clutter up other threads with this talk and we can have it in one dedicated thread.
So @jlbayes you're the second person now I've seen post in the last couple days saying that the lower stall speed was terrible. Seems weird that builders like @Dynamic are using the slightly lower stalls, but the end user isn't happy. Is it just a preference on your end or is it actually performing bad? @Dynamic you said that the slightly lower stall speed was good up to around a 62mm sized turbo right? @jlbayes what size charger and stall speed where you running?!
Tagging for sa purposes: @CSM @Silverdodge @Me78569 @JAG1
  • Replies 32
  • Views 8.2k
  • A converter will stall differently depending on load.  However, it will fall within a general range.  You can think of it as the RPM the converter changes from a turbine that converts a given torque a
  • quit getting along and understanding each other....this is an internet forum and we have no room for that behavior       oh wait...   No you guys are good hahah
  • This isn't bookface.....
So here's another question, what is considered stock stall speed? I've seen multiple different answers, some say 1600 while others say 2300, is there any really way to tell?
Also wouldn't it make sense that if I have say a stall speed 2-300rpm lower then stock and then increase my hp/tq numbers that that number would increase?
On 3/24/2017 at 10:10 PM, CSM said:
Last note, I have had an intermittent lockup hunting problem that I haven't yet found the fix for.  The low stall converter is much less violent than a high stall when it moves in and out of lockup.
have you started a thread about this? Or when you say intermittent is it based on humidity?
Stock when accelerating i saw 2,100 rpms regardless of how hard i put my foot into the throttle, not sure if this helps.
Yes. Power brake the transmission the point at which the transmission starts pulling on the drivetrain  at it max rpm is the stall point in the basic sense. I'm pretty sure you'll have a tough time doing this. Old school method of checking stall speed.
I havent started a thread.  It comes and goes.
This is true, but if you exceed the stall speed and lock up the tc you risk destroying the TC, and or snapping shafts, just hope you have a billet input shaft, because when they let loose they usually take out the TC and the transmission pump with it.
I'm not saying mat the throttle to the floor to test it. Like even in my 96 Dodge 1500 it extremely difficult to do being the tires let go before you reach the stall speed. Like the older 727 transmissions you could do this fairly easy back in the day.
I agree.  It will give you an idea, similar to if you floor it off the line.  The RPM at which you really start to feel the push and stop seeing your RPM rapidly change is your stall at that load.
Stall changes with load, engine RPM, and engine/trans differential RPM.
Edited by CSM
On 3/24/2017 at 5:23 PM, notlimah said:
Sorry if I was coming off in a way that said you should feel differently about your experience. Completely understand your point and value your opinion.
I was just trying to point out that it seems weird that trans builders and recommending one thing and then guys are running it with sub satisfactory results.
Maybe it's just 100% user based opinion and subjectivity regardless of whatever 'the right way' is. Or maybe just an expectation that isn't realistic given the setups? I don't really know as I'm still on a stock trans but in a couple months I'll have a different opinion so I'll chime in with first hand experience then.
Again, sorry if I came across like I was trying to tell you your experience should've been any different then it was. :thumb1:
It is hard to convey tone across text. Dynamic argued with me before on how my truck was behaving. Do not take it personally. :cheers:
Completely understand! :cheers:
oh wait...
oh wait...
