Overhead Console Showing 'CCD'...
- Replies 11
- Views 5.4k
Me78569 2 posts
SilverMoose 2 posts
jlbayes 2 posts
BBHD 1 post
Popular Days
ccd bus means the overhead cannot read any incoming CCd message. If hte cluster doesn't show it then it is likely a wiring issue in the overhead.
Under the garage door opener section there are 2 plastic tabs just press them and pull back on the hole thing.
^agreed. Check the connector at the overhead console.
Does anyone know what that's about and what to do? It goes back to normal for a short while after a battery disconnect.
Thanks in advance
