Fuel pressure goes up on Accel?????
- Replies 49
- Views 10.8k
JAG1 18 posts
Mopar1973Man 11 posts
notlimah 6 posts
dripley 5 posts
Update; after running return line in a bucket which revealed no restriction and doing some tests on the electrical (found minor voltage drop from bad alternator/ engine grounds) I went ahead and chang
Haha wonder if it was just air stuck in the system taking its sweet time to work itself out!!??
The fluctuation sounds just like the grid heaters cycling. Do you have them disconnected at the battery? Can you check the voltage going to the pump when rev it to see if the voltage is sp
All new Mechanical gauge, big line kit, Draw straw, just tried second brand new Raptor 150 and fuel pressure goes up with acceleration and rpms.
I adjusted to 18 psi but the dang pressure drops back and forth between 18 and 15 at idle..... you can time it with a watch, back and forth. Then when you rev it the pressure goes up way too high. Grid heaters are disconnected and I checked with a volt meter for voltage fluctuation but it's charging steadily when engine is running
I switched to a different new raptor 150 today thinking it was the pump regulator... weird... because after you adjusted it to the 18 you get going down the road and the dang pressure goes up
as high as 25.
My 02 does not do this........ pressure is steady till you get on it and it drops to about 16 which is normal.
Any thoughts....?
