- Replies 25
- Views 13.7k
dripley 6 posts
JAG1 4 posts
Mopar1973Man 3 posts
jlbayes 3 posts
http://www.skf.com/binary/30-283852/TT08_021.pdf Here is another link from speedi sleeve, a thin coat of loctite between sleeve and crank would probably aid in sealing
@dripley just keep in mind the front seal is a dust lip and tends to cut into the crank. Now the polished ring behind is the actual oil seal riding area. So that groove your pointing at is caused from
Many have done it without issue. So yeah, it seems to work. Nice thing about it is both seals are offset from the stock one so both have a fresh place to wear to the crank.
Which way is the nut threaded, righty tighty lefty loosey or the reverse? About to take mine off and dont want to drive myself crazy, I know its on there good. I have plenty access.
Edited by dripley
