How Hot are Your Hydroboost Lines?
Hey guys, I'd just like a quick poll of how hot the lines running in / out of your hydroboost are after driving for a bit.
Thanks!
  • Replies 32
  • Views 13.8k
  • I dont have any way to check the actual temp, but after idling alot and a very short drive I cannot hold them with my finger tips for more than a second or 2. I can hold the return the longest.
  • Don't touch them mofos after even a minimal length of time.......
  • Dieselfuture
    Dieselfuture
    I think because Mike always staying on top of fluids that's why his still on a lot of original stuff. Part of reason I started to try and stay ahead of game and also listened other peoples advice here
Thanks!
Can we get a couple more? @trreed @jlbayes @Mopar1973Man @Me78569 @JAG1 Spill the beans gentlemen!!
Mine can be hot after running the truck on the highway for 3 hours then get even hotter sitting in parking lot idling for 4 hours. But my daily driving locally arond home it stays rather cool to the touch.
Hmmmm. I will have to check mine after a good drive and see how different it might be. Mine is hot mostly from idling and a very short drive.
Mine are hot enough to not touch for long after a little highway and some stop and go. Maybe 3 or 4 seconds on pressure. The return is cooler but still toasty. :2cents:
Thanks guys. I'm going to replace my pump (for the 6th time) and the hydroboost and was wondering how hot they "should" be. I'll make sure to flush everything really well before installing.
You thinking your pump is causing the fluid to be hot? I was thinking of changing mine out when I reseal the vacuum pump just because it is the OEM and got 415k on it. Do you change the reservoir too? I see rebuilt pumps are about $30 cheaper without the reservoir.
I've never removed the reservoir. At my local Napa it's 50 for a reman pump with reservoir or over 100 for one without.
I think the hydroboost is plugged making the pump work extra hard and burning it out. I don't think my luck is so bad I've gotten 5 bad remans. Plus it all started after having to lay on the brakes super hard with 20k on the back.
I wonder how hard they are to reseal? The kits are only 10 bucks or so.
After a 2 hour drive on the freeway towing at 85-90-ish, my lines were hot.  Could hold them for about 5 seconds.  Later, lots of city driving and idling, I could only touch them for about 2 seconds.
Update - I put a reman hydroboost and a new power steering pump on. Right away I noticed the brakes were easier to push. I've still got a really slight groan when turning around 1100-1200 rpm, but not nearly as bad as it was. There may be a blue top box coming in the near future.
Before the swap, if the truck idled for 30sec or so the lines were hot, now after a 10 min drive I can keep my hands on them without an issue. I'm sure it'll get hotter during the long drives, but it does seem better.
I had the same problem all I did was flush the system out with some Walmart Supertech power steering fluid and that is gone. Fresh fluid does wonders.
You not using ATF by chance are you?
I flushed everything before installing the new stuff.
Nope, I bought a gallon of Napa conventional power steering fluid.
You've got a restriction somewhere. If it was me I would just put $30 in a seal kit pull the steering box apart and rebuild it and find the restriction than messing with a redhead or blue top box. I can rebuild that sagnaw in my sleep its so easy.
Yes, I'm sure it's when the hydroboost started acting weird. It probably sent something downstream to the box. I'll look at rebuilding it, but it is getting up there in mileage. Might be best to get all new bearings and everything in it.
