If I am going to do tie rod ends and steering components
- Replies 38
- Views 6.5k
Mopar1973Man 6 posts
Dieselfuture 6 posts
portlandareae28 6 posts
Killer223 5 posts
Popular Days
Not sure how well you can see it but basically it's a stock bar that I cut ball joint off and welded a pice of round stock same I'd as bushing side of track bar, went to parts store picked up poly bus
Here's a pic for those needing a visual to go with @Dieselfuture'a description.
I am like you in not understanding the benefits of Y vs T. I am convinced there must be some difference but the only way I could know is to swap it out. I might do just this in the near future we will
On a stock height, stock tire size 3500 dually do I really need to worry about upgrading to 4th gen parts? or will good aftermarket stock parts hold up another 300k miles?
