In tank, Lift Pump Retrofit
Folks,
in 2010, I put the Dodge in tank Lift Pump retrofit into my 99.  Its been rock solid since.
As some of you might know, I have recently made a bunch of changes to my truck (ECM, Inj Pump, 275 Bosch injectors, 2000 Fuel Filter housing) and this afternoon the lift pump pressure started doing wonky things.  its normally around 18 or 19 @ idle, and 14 or 15 cruising down the highway.
Sunday I took the truck/Trailer/Buggy for a ride to make sure it was happy with the hills around my area & it seemed to be quite happy.  when I got home I put the trailer away & filled up the truck to see what kind of mileage I got (10 BTW).
When I got home I put some of the 2 stroke oil in it & put the truck away.  When I was headed home this evening I noticed that the fuel pressure was lower than I expected it to be, so I whomped on it & it dropping down to 7 or 8 Lbs.  I dont think I have ever seen it that low..........  and to go from 20 Lbs to 7 Lbs is very concerning...
so......... Im wondering.........
A: How long do these pumps live?
B: Can a slight leak in #3 injector line (@ the transfer tube), cause this to happen.....
C: Is there an easy way to pull 33 Gallons of fuel out of the tank?
D: Does anyone make a good in-tank pump?  I know everyone is going to say put a FASS/AirDogg/AFE/ETC, pump on it.  I could but, I do like the in tank option, and if Im going to have to drop the tank to take the OEM pump out, Id like to put another one in.
E: How long do FASS/AirDogg/AFE pumps live?  10/15 years, 100K/150K?
F: Is there any reason to think that adding the 2 stroke oil into the fuel could cause this?  I cant imagine it would, but thought I would ask;.....
thanks Gents.  Im back to hating this truck again.  ROFLOL.
Bob
Edited by Bobalos
  • Replies 64
  • Views 13.1k
  • My experience: lifting the bed is super easy.  I do have a short bed.  What I do is starting at the front of the bed (rear of the cab) and remove the first 4 bolts and the ground strap.  Then on the t
  • @trreed, thanks, I think Im going to give this a go.   @Dieselfuture, Ive seen that before & never really knew what it did.  Very cool option to forums.    Ive learned something today, I
  • From what I've read, thing not connected at top works as vent on diesel and on gas line goes to charcoal filter.  I put filter on mine to keep dirt out.  Filter was cheap ace hardware lawn mower filte
I would say 250 -350 lbs., so your only dealing with half that weight when lifting the front. I used a 4x4 about 2 or 3 feet long on top of a floor jack and raised the front like a dump bed as close to center as the driveline would allow till I could place a 12 inch long 4x4 on top of the truck frame on each side for safety. I used the two rear bolts as a hinge when loose and to hold it stable but watch the bumper hitting and don't hit the cab when you raise it. I think I had to remove the license plate plastic too.
16 hours ago, 015point9 said:
So how much do people think a 8 ft weighs?
Enough that you need 3 to 4 people to safely lift the bed with damaging paint. They are heavy and awkward to lift and move. I've seen several people here use straps in the 4 corners and then use a forklift or backhoe to pick the bed up off the truck. If you have a 2 post I've seen guys use those to lift them straight up.
Me... A empty fuel tank is very, very, light and two bands I can drop a fuel tank much faster than lifting the bed.
i lifted the bed on my 02, took 2x6 and turned on edge between the bed and frame then wedged a 2x8 in there, was plenty of room then.
When do you plan on doing this?   I see you live in San Diego.  Del Cerro area?  I'm a half hour north and can help you with this, I've dropped a few tanks over the years.  I have my work van with tools, floor jack and 5 five gallon fuel containers to pump your fuel into.
@ibmobile, thanks for the offer.  I have 2 strapping young men here that I used as slave labor (my boys).  Lol.  It was very simple to get the bed up.
I will write something up when I get the pictures downloaded.
Next.....  I wonder if the pump is not fine and the filter is just plugged...   It is WAY dirtier than it was Tha last time I removed it.  Last time it was pristine.
I chickened out and went with what I know and bought another oem setup.  This is an intermediate step.  I need to get it running then will worry about upgrading it next summer.
So..... Now I'm wondering if I should remove the filter from the new one and just let the filter do it's job.  Seems like a good way to ruin a fuel pump but what is going on now is not good.
The real question is how is all of this dust getting into the tank....
So what does the fitting on the left do??  The one that is not connected to anything?  I'm guessing it's the vent for the tank.  I wonder if that is not how the dirt is getting into the tank...
This is the back side of that fitting...
I hate to keep throwing up all of these questions without anyone having a chance to reply.....
So what does this thing do?  I'm guessing it's a pressure regulator.  There is a spring in it that pops open when the pressure gets to high.  This way they can out in just about any pump and it will give them the output pressure they want...
From what I've read, thing not connected at top works as vent on diesel and on gas line goes to charcoal filter.  I put filter on mine to keep dirt out.  Filter was cheap ace hardware lawn mower filter.  I'm long from expert though.
Service manual says "Rollover  valve"  (however mine does not look like pic in manual).
FUEL DELIVERY - DIESEL page 14 - 79
Well...... I just got back from a test ride & the fuel pressure is awesome.  15+ @ idle and I could not get it to go down <12 @ WOT.
thanks to everyone for the help.
If anyone is interested I can write up a thread on how to do this evolution & everything that is involved.
Bob
FWIW, I blew and sucked through both the old & new one & I could not get it to stop the flow in either direction regardless of orientation.  seems like a vent to me with a little cotton/screen/filter in it.
Bob
I thought about doing the same thing.  however I needed to get some stuff done today (Honey-do list stuff) so I opted to just put it back together & get it going.
23 hours ago, Mopar1973Man said:
Just go over to the article database and post it up. We'll review it.
Done.  I meant to edit the pictures, but the only thing on this computer is paint & its a PITB......  I had to make the pictures smaller so I would not go over the upload limit.
Hope you like it.  :)
Bob
13 hours ago, Mopar1973Man said:
Should of reused some out of the file pile you got...
I dont know what this means..
When you make a post on the site all your images are stored in your personal file area.
So there is a button in the lower right saying "Insert other Media" when you click on it gives two choices insert existing attachment and insert image URL. You want to select insert existing attachment.
So this pops up now you can select from any image that you have in your storage. Instead of uploading multiple images that are the same.
Oh shoot.  Gotcha.  I didnt realize that it organized them per user.  thanks.
Bob
The problem is if I leave it unrestricted people would continue to just keep uploading photos and files non-stop regardless of being a repeat. The server would quickly become full and we will have to buy into a larger hard drive increasing the cost of operation. Hence this why donation member gain more storage space being they contribute to the site.
Member is 25 MB of storage
Silver is 50 MB of storage
Gold is 100 MB of storage
Platinum is 250 MB of storage
I looked @ the one I pulled out a little bit closer & that is exactly what it is.  turn it over & its very hard to get air to go in or out, turn it right side up & its very easy to go both ways.
Thanks..Going to look closer at what I have. I wonder if it's any great crime not to have a "turn over" valve?
Old one had one but not new one.
That allows air into the tank as the fuel is pulled from it. You need a vent of some sort or the tank will start to collapse and starve your fuel system.
Fleece performance just came out with there new factory intank pumps, they look great and act like stock. Supposed to hold up to 800 horse.
