This thread is for the results of the testing of the differnece pop pressure at the same size.
ANY REPLIES NOT ON TOPIC AND OR WITHOUT DATA WILL BE DELETED.
I will be running 3 sets of DAP injectors first set at 305 bar, next at 330 and the last at 350 bar.  We are going to compare real world situtations and what the pros and cons are of increasing pop pressure.   All tests will be datalogged and video taped if applicable.
The tune will be EXACTLY the same for all injectors.  al runs done on Lvl 3, so no wiretap being used
Quote
Timing Parameters
Fuel Load Timing 3
Low PSI Timing Reduct 5
Timing Reduct Scaling 50
LightThrottle Timing Adv 1.5
Light Throttle Limit 30
Timing Equilzer
1500RPM 17
2000RPM 20
2500RPM 23
3000RPM 28
MAX 30
Boost Level Fueling - CAN Bus
0 PSI 66
1 PSI 66
2 PSI 67
3 PSI 68
4 PSI 70
5 PSI 71
6 PSI 72
7 PSI 74
8 PSI 76
9 PSI 78
10 PSI 80
11 PSI 82
12 PSI 84
13 PSI 86
14 PSI 90
15 PSI 94
16 PSI 98
18 PSI 102
20 PSI 106
22 PSI 110
24 PSI 114
26 PSI 118
28 PSI 120
30+ PSI 120
Test conditions.
Quote
1. 0-60 WOT take off, same stretch of road
2. 55 mph egt on same stretch of road showing egt
3. Lugged 45 mph locked od pull to compare spool.
305 BAR
Test 1 0-60 WOT take off, same stretch of road
Test 2 55 mph egt on same stretch of road showing egt
Test 3 Lugged 45 mph locked od pull to compare spool.
330 BAR
Canbus fueling is ~1125 and egt right around 710-725*f  ( road is slightly uphill
350 BAR
Edited by Me78569
  • Replies 163
  • Views 29k
  • 330 vs 305 bar 0-60 So results between the tests,  Both tests were WOT snap from a standstill, same stretch of road, and ambient temps within ~5*f of each other.      Note the area
  • 350 bar injectors are in an WOW is all I can say.  When comparing the 305 bar to 350 bar I could EASILY run a tune starting %5 higher with the 350 bar injectors and still have significantly less smoke
  • dieselautopower
    dieselautopower
    Thanks for the update.  I want those injectors to run good for you.  I would like you to send them back in.  Check with warranty@dieselautopower.com and lets get it fixed for you.
1 hour ago, pepsi71ocean said:
Nick, I was talking to Mike, and I was thinking of 315 Bar on my 100hp injectors. What are your thoughts?
Bear in mind I still have an S03, and I'm willing to play to see if I can get this smoke under control.
I doubt you will notice any difference.  Duration commands causes %95 of the smoke.
Time for new tuning.  After I logged the s03 putting timing at 17* and holding I officially disregard the s03.
When you say disregarded you mean shelved? I was talking to Mike about the touch, but I'm wondering if setting them higher may help with smoke control.
Maybe higher more like 320 so that they settle down at 310?
I did talk to a injector ship that is local to me that is willing to let me watch the atomazion and setting the new pop. They are a set of dap injectors, and if this shop didn't say they would have them back in the same day then I would have sent them out
The S03 tuning does not offer good tuning.   Stock injectors maybe for fueling it is ok, but the timing tuning is better left to stock for any application other than peak torque on a dyno at 1800 rpm or cruise state.  I personally liked the timing curve of OEM better when running a higher SW level.
Going to 330 bar helped for smoke, but your efforts are better left to tuning rather than pop.
If you want smoke control get better tuning.
@pepsi71ocean has a few things against him...
  • Smarty S-03
  • Low stall torque converter
  • +100HP injectors
I agree, the Smarty S-03 programmer isn't designed for +100HP injectors. Then toss in the low stall converter and making the problem worse. The only thing I can figure is the injectors might be a little soggy and down in pop pressure and the re-pop might help some for clean up and MPG.
He could go two directions either Quadzilla Adrenaline or Smarty Touch. Optional would be change the torque converter for slightly high stall or stock stall to allow for spooling of the turbo.
That's what I asked dap to set mine to and so far I love it, no smoke at all on idle. My tune starts at 80 now even on my previous tune starting at 86 it was not that smokey but definitely more power then the 75hp I pulled out.
New issue anyone think it could be injectors?
Very randomly during longer idles the truck will will suddenly act like someone did a quick blip to wot..
Also after doing stuff that uses more fuel, hard pulls, going fast, passing idiots, While costing in gear slowing down completely off throtle it'll suddenly jerk like it it just got a shot of fuel.. hard to explain i finally got a data log of it tonight but haven't looked to see i caught it or if you can see anything yet
Mine did that this past weekend, but while I was coasting in neutral.  Couldn't put words to what it did at the time but that's exactly it.
Edited by trreed
14 hours ago, Dieselfuture said:
It's got to be a twin thing :shifty:
I chalked it up to angry VP and kept going.
Though, @Dodgeih and I do have the same size injectors. Could be an injector thing.
Edited by trreed
How long have you been running these at this pop pressure? I'm really thinking this is the happy medium pressure to test run.
Even with the S03s limitations I have done allot of testing with the S03S to the point where I can get grey smoke and not black. So I assume that means the timing changes are before the smarty locks it.
Timing always locks at 17.2* if duration is maxed and tps is above 60,70,80 % depending on the T setting in the tune.
Keep in mind that I had starting issues when cold cold when pop was at 350 bar.   330 didn't have the issue as far as I can tell, but it wasn't as cold with the 350 injectors.
My duration settings were always between 2 and 3, anything higher was to much smoke before the turbo would fire up.
To me I noticed that Changing the timing setting and then the SW could produce grey smoke and not black smoke. Also could change how much smoke was produced as well.
I actually thought grey smoke was bad, till I was taking to the injection shop the other day and he was telling me that Changing the pop pressure will change your smoke colors. Which I found odd.
Although he said raising the pressure will effect where in the Piston the fuel hits the bowl. Which is he concern with me raising my pop pressure
I'm mostly courios if raising the pop pressure a bit would effect that low end drag smoke I get for a few seconds before the turbo lights.
Only for few hundred miles, so yes I can't speak for long term.
This is what my pattern look like with regular Pop pressure, so increasing it a little bit should make it fire later and put it more in the bowl
5 hours ago, Quadzilla Power said:
Try to take a data-log of the event so that we can see if there is an errant fueling message. However, its probably an injector thing. Make sure that your filters are clean.
I have one I just have not looked at it to see if there is any evidence of what happened. I will not have time to stand through it probably for a couple more days. I can attach it and if someone's wanting to look it is right towards the end of the data log. As I'm coasting. I was going about 90 mile an hour before and was coasting to a stop sign when it happened....
surge.csv
going from 305 bar to 330 bar gave the same effect of dropping duration by %2-%4 without actually lowering fueling.
Dunno how the fuel placement would be noticably different.   Gotta remember hte vp might pop injectors at 305 bar, but peak pressure is WAY higher.  The amount of time difference between 305 bar and 330 bar in terms of when the pop event happens is nominal at best.
Sounds dumb but I thought DAP injectors where set for 300 bar?
I had to go back and do some digging but that is what I remember they were back in 2013 when I put them into the truck. Since then I have added about 30,000 miles onto the truck and most weren't an easy 30,000 miles either.
Edited by pepsi71ocean
I shoudl say "stock bar"  whatever that is.
Mine are at 300 and they gud2go
They're smaller then we’re discussing here but that’s what was recommended to me.
