Stupid Coffee Makers
- Replies 11
- Views 3.4k
Dieselfuture 3 posts
dripley 2 posts
Marcus2000monster 2 posts
Me78569 1 post
Popular Days
Why buy a new one, you already performed your first mod on the old one. Put a quad on it and you can time the next pot perfectly. Just a personal opinion.
I buy the cheapest coffee maker WalMart sells. They cost around $12-15 and last 2-3 years making 2-3 pots a day. I rotate the new one to the 5th wheel the old one to the house and the broken one to
We had the same problem with most of the appliances in our home. We switched to a Bialetti Moka coffee maker and never looked back. No electronics to go bad, better tasting (less sour and stronger)
I bought a name brand Mr. Coffee - Coffe maker. I bought the simple version of just the toggle switch still without all the clock and stuff to go wrong. Would you believe after barely 6 months the simple toggle switch failed? Yeap. It quit working. I wanted coffee so I broke out the screwdrivers to start pulling it apart. I'm greeted on the bottom of the coffee maker with a warning that there is no serviceable parts and you should not open the coffee maker which might put you at risk of a fire. Screw that... I proceeded... 4 screws are normal Phillips but 2 screws are Allen wrench. Are you kidding me? Ok back to the shop I cheated again instead of Allen wrenches I grabbed a T10 Torx screwdriver it fit perfect. Pull the bottom off pull the two leads off the switch mated the two blade connectors together crushed them tightly with my multi-tool. The wrapped it up with electrical tape.
Sweet sound of coffee brewing...
Now in days everything is made cheap and mostly made of cheap plastic. So next time I head to Ontario, OR I'll be buying another offee maker for us. This is just sick and wrong why doesn't anything last?
