4x4 spin free locking hub spindle kits
Does anyone have a 4x4 locking /free hub/spindle kit on their truck?
A guy's dodge truck in the shop has the yukon free spin kit installed.
He said he gets better fuel mileage and he can feel the difference driving around
I always thought about installing one of these kits. Cant remember what brand I was looking at
  • Replies 32
  • Views 8.3k
  • 24valvematt
    24valvematt
    I have a 1 piece from a 4th gen cut down and the flanges changed to 1410 for a 2nd gen. I love it
  • I have the Yukon kit, as does my dad on his 06.    Mileage gains were negligable, but I spend most my time towing/hauling so a 5-10% gain is harder to see.    It does feel much bet
  • Dieselfuture
    Dieselfuture
    What I'm amazed at is after all this time we still manage to find something to talk about, to some old info to a lot new.
Guy I used to work with has one on his 06’ dually, same story. But goodbye to $2,000
  Yeah,,, No sh*t !
It does feel much better driving around as the steering wheel takes noticably less effort. I can tell when I've left the hubs locked just by the steering wheel feel.
I paid around $1500 for mine and installed them myself. Considering the cost of replacement sealed wheel bearings it's not that bad, and I can service them.
I did my first service last summer at about 30K miles. Everything still looked new.
2Lo is also a very handy feature.
Does it use common bearings or is it special, I think I'm almost due for front hubs and kinda considering going free spin. What about abs stuff is it all incorporated.
Good question I can't remember if I've ever seen the ABS sensors on the 2nd Gen kits... :think:
Yukon has kits listed '99 and older , different kit for  2000 up trucks
Is 2000 the first year for front abs?
Glad my 99 doesnt have front abs.
Is there anyway to delete/disable all the front abs junk on the 2000 and up trucks?
There are tone rings on the wheel hubs for 4 wheel ABS in 2000+ trucks. Yukon is not compatible with 4 wheel abs for 94-99.
The bearings, seals, and even lockouts are all Dana 60 standard. The stub axles are Dana 60 but with more splines, so the the lockouts also are slightly different. 35 spline stuff is petty common these days thou.
Why would you want want to disable front ABS
1 hour ago, AH64ID said:
Why would you want want to disable front ABS?
Might be because he's running oversized tires (285's) and the ABS computer has never been updated with the proper rev/mile so the system could work as its designed.
NO. As the abs module is used for the speedo.
Waight a minute here, are you saying if my computer is flashed for one size tire and I'm using another, then abs/brake light will come on periodically
Possibly. Yes.
All depends on how the speed signals are read and what 3 values your have from the 2 front and 1 rear sensor and how far off the signals might be plus on the automatics there is the output speed sensor that could be used too. (Not sure but possible.)
For me it only 1 rev/mile different for 235 to 265 rev/mile difference.
265 (638) and 285 (615) there is a 23 rev/mile difference.
If all 4 tires are the same it is very very unlikely that oversized tires will throw a code. The ABS module may not know the actual speed you're going but it won't know that.
AFIK the trans sensor isn't used for speedo/ABS but rather for shifting, so it too shouldn't care.
Just like I found out that the Battery Temperature Sensor is used for the grid heater post-heating. Strange but true. Being the speed sensor is stored in the PCM it could be shared by the CCD Network bus. Possibly used... Maybe? :shrug:
  • 2 months later...
So I wanted to revive this for a minute. I am wondering why no one has come up with a conversion that replaces the carrier bearing spindle with a spindle that uses a conventional, rebuildable bearing and finishes the conversion with parts we can scavenge at the junk yard or already have? There's a Ford f250 rotting in a field in a town just a few miles from me, has the ttb 50 front axle as the guy wants next to nothing for it. Maybe I'll drive out there this weekend and tow it home for the sake of tearing it down and seeing what can be done.
Several folks have gone to a 1 piece driveshaft to eliminate the carrier bearing. They seem to have good luck with it. I have no personal experience with one, just what I have read.
I don't think I'll be doing anything with the cad except maybe a manual kit since I don't have the computer to lock/unlock like you guys do. I'm mostly after eliminating the unit bearing and adding some hubs to reduce rotating mass
CAD is vacuum switch.  No computer control.
Sure but there has to be something to tell the vacuum when to apply/not apply. This usually takes a button and a transfer case control module. In any event I don't have vacuum, I ditched the dodge style power steering pump in favor of a pump that moves enough fluid to run hydraulic equipment when I need it.
Our transfer cases use these mechanical vacuum switches.  Regardless, the Chevy transfer case would be difficult to adapt a mechanical switch into a motorized unit.
If you don't have a vacuum pump/PS pump combo, how do you use your HVAC controls? And is the replacement pump able to run the power steering and your separate circuit for your other hydraulic needs?
