What an evening
Got off about 4:30, got back to the room and figured I would take a nap then get some dinner. Just kicked my feet up for the nap and get a call from CFA that the sewer line is stopped up. Get a plumber there and we open the manhole and are greeted with this.20180522_195756.jpg.f698ea9d2d6cfc04b0b6ac674ad46492.jpg
  • Replies 19
  • Views 5.1k
Looks like a crappy evening.... Literally
Reversing connecting rods would have been a lot more fun. Might have got beer while I was doing it too.
9 minutes ago, IBMobile said:
Knew you had to have one that. BAWK!!!!!!!!!!!
Grease trap interceptor not functioning properly? May find a post hole digging tool handy for getting that out.
Yum Yum :drool:
Yum Yum :drool:
At first I thought it had to grease. That manhole is down stream of the interceptor. But a piece  #3 rebar proved me wrong. Definitely no grease, just poop and tp plus various other none flushable paper products. Even found a stolen credit card. Turns out after rodding and hosing it all to break it up I found about 6" of recycled concrete in the bottom of the manhole fouling things up. Never knew poop could clump up into a 20 pound s**t brick.
Edited by dripley
There is no way you are paid enough.
That job didn't match your credo for sure, "Overpaid and Underworked".
Dang. I thought this was going to be about a cocktail or couple on the deck enjoying the evening fade away into mosquitoes and awesomeness.
I was wrong.
Edited by Ben
Next time i will be more thoughtful and invite yall along. The fishing was plentiful. Ahhhh, natures bounty.
Did you warsh yer hands before getting in your truck?.......
I dealt in that type fishing once.... made $2150 in a day and a half about 12 years ago :USflag:
A couple times. After getting to the room a cleaning up even more, I could still smell it until i fell asleep. As far as pay goes, I got paid on Wednesday just like always.
 I was fortunate enough to have a plumber with a drain snake. He was able to get the snake thru all of that and into outfall pipe. I ran the jet to break it all up. That's customer service!!
At least dumping the RV is much easier than lifting man hole cover and seeing that... :sick:
Wish we would have had a simple dump valve to open.
Speaking of which...... I found out cranberry juice works better than RV toilet tank deordorant. It works so much better I was astonished when I had to dump twice the amount of RV black tank treatment needed to get the same results as cranberry juice when I ran out. The cranberry juice was a cheap brand with citric acid as one of the ingredients. Just so you know.... Its better for the septic an drainfield too.
8 hours ago, notlimah said:
How much juice?
I poured about a fourth of the bottle in there each treatment, that's just a guess since It may have been a half gallon bottle.
 What happened was I bought what I thought was good juice, but saw the ingredients had citric acid which my dentist tells me to avoid, so I  tried dumping it it in the black tank and see if it made any difference. I was amazed how well it worked till the tank was emptied a week later, without any other treatment in there.
