Ready to do a fuel system
- Replies 23
- Views 3.9k
Mopar1973Man 6 posts
notlimah 3 posts
015point9 3 posts
portlandareae28 3 posts
Popular Days
Basically the main reason I went with a FASS over the Fuel Boss the first time was the filtration. I liked the smaller fuel filter and water separator that came with the FASS and I didn’t want to use
Use what you read here and what you find in your research to make an educated choice.
Don't see how but if it works great. Old neighbour told me when his car failed smog test he brought along a scuba tank and added oxygen to exhaust and passed.
I am moving to California at the end of June and think maybe I don’t want to test the DDRP for the 1200 mile trip towing. I am trying to figure out which system makes the most sense, and if it comes with everything needed for the install. This truck is stock except edge comp (not tapped currently due to not having a fuel system). It will never see more than a 75-100hp injector (assuming I can do anything in the people’s republic of California)
Fass, airdog, or?..
which model and why?
what do I need in addition to the system for install? Hoping to not have to drop the tank before I go as I am running out of time.
i appreciate any and all help/opinions. (I may be open to the belt driven mechanical pump setup)
thank you
brian
