Aftermarket injectors?
- Replies 26
- Views 10.8k
SavageTusk 8 posts
Mopar1973Man 6 posts
CTcummins24V 2 posts
notlimah 2 posts
Could just buy a second!
My recommendation, get Bosch bodies, new or reman. I've run new and reman bosch bodies, never had an issue
Most will suggest VCO nozzles over SAC. I'm running 7 x 0.0085 VCO DAP injectors.
I am thinking about picking up some injectors. Anyone have experience with DAP Aftermarket injectors? Here's what I'm looking at. Obviously I'm looking for a lower cost Injectors, I have stock now. I'm running a 150gph pump, turbo upgrade is after the injectors.
Set of 6 Diesel Auto Power 125HP Aftermarket Performance Injectors for Dodge 24 valve Cummins. 7 hole (0.0095 inch holes) SAC style. Compatible for years 1998.5-2002. Installation kit included: (Injector connecting tube removal tool/nut, copper sealing washers, and o-rings for connector tube). new copper washers
