Head gasket blown - Coolant leak
- Replies 155
- Views 31k
Mopar1973Man 52 posts
Dieselfuture 22 posts
dripley 13 posts
trreed 11 posts
Mike, Truly my pleasure! You do more for people with no expectation of anything in return than 99% of the people on this planet. I have not always been in a position to financially help
Well first off I've got to Thank a forum member... But first the story... After going back and forth with it not going to be ready today to being ready at 3:30pm. I finally got ahold of Mo
(With a Mad Scientist voice) It's alive! It runs once again! I'm quite amazed. I got it started and left it idle while I picked up a few things then kicked it out the door to warm up more
Happen to be walking by the truck parked in the shop and noticed a small puddle of green coolant. It where its at which is strange. Back at the bellhousing. I know the only freeze plug back there is the block freeze plug but as far as I can see right now there is no coolant coming from that freeze plug but I fear the worst.... Possible head gasket.
