- Replies 15
- Views 3.3k
dripley 3 posts
JAG1 2 posts
Dieselfuture 2 posts
Sycostang67 1 post
Red, Black, it really doesn't matter. May be they ran out of reds and put in the blacks. The material they're made from isn't important so long as the bessel doesn't rattle or squeak. I get extra
Getting the bezel off without breaking the dash or the bezel is the real trick. My bezel is currently held on by 1 factory clip, a metal brace I made and a piece of gorilla tape. That lense comes off
It separate of the bezel just like the later models
Found this. Is there any tricks other than the video? Do any of the clips or red clips thingys get ruined or need replacing after one removal or if you remove the bessel several different times will any of the clips or red holders get ruined and need to buy more or anything like that??
Notice in the vid the red clip holder to the right of the heater/AC knobs , it looks different. Is that one broken off?
Once I get the Bessel off,,,, My speedo area has a lot of dust in there behind the clear plastic. Can the clear plastic be removed (screws) to clean all the dust out behind it and wash the clear plastic piece?
Edited by GSP7
