R and R Engine Dampener,
- Replies 11
- Views 2.7k
Mopar1973Man 2 posts
JAG1 2 posts
015point9 1 post
Bullet 1 post
Popular Days
Don’t use your hand for a hammer!! You’ll regret it when you get older
Shocking the bolts is a great way to do it. I had to remove the dampener bolts when I installed the fuel boss. I used a breaker bar and a 5lb mini sledge to smack it with. It's best to maneuver (by
You need to shock the bolts. You can't get an impact gun in there. Just pulling with pure torque most likely with just turn the crank.
I have an automatic trans so what is the best way to hold the engine from spinning while loosening bolts on the dampner? Changing this weekend since the rubber is supposed to be even, flush to the steel. Mine is mushed out all around and wobbles when running.
