Fuel boss install on 2000 2500 that has stock lift on block and an in-tank pump
- Replies 17
- Views 2.5k
dripley 5 posts
backcountrymountains 3 posts
Dieselfuture 2 posts
Me78569 2 posts
Popular Days
Thanks for all of the advice, called Richard from Glacier Diesel and he said as long as I can't hear the pump in the tank it's probably good to go. He said the in-tank pump doesn't allow for fuel to f
pull the fuel level basket and find out before you buy anything.
No holes in the bottom of the tank for me. The pick up in the basket will drain my tank.
First time posting. Just got a 2000 2500 2wd to tow a tiny house. Decided to get a Fuel Boss and hopefully not worry about fuel supply issues and trashing a VP44. The thing is bone stock (as far as I can tell) without gauges (I know I need to get them).
I checked the engine bay and there is definitely a carter lift pump behind and below the stock fuel filter. It's plugged in to the harness and the fuel like is hooked up to the filter, but I haven't bumped the starter to see if it runs. I ordered a fuel boss thinking the install would be straightforward with the stock lift pump.
Then I checked the tank. It really looks like it has an in tank pump: 4 wire harness, inlet, outlet, and vent.
What the heck?!?!?
Is it possible to have an in tank and stock pump? Isn't that too much current for the ECM?
Is it possible to suction fuel through the in-tank pump to the fuel boss? Do I have to put in a draw straw? Saw this video: Fuel tank module upgrade from Throroughbred and they showed how to just cut out the in-tank pump and add an extension to the stock straw instead of installing an aftermarket straw. Any reason that wouldn't work?
I'm not looking to add HP or anything, I just want a reliable fuel delivery system.
Thanks,
Justin
