- Replies 25
- Views 4.1k
dripley 4 posts
NIsaacs 4 posts
Dieselfuture 3 posts
Mopar1973Man 2 posts
Lots more available power on a stock fuel system, and very easy to mis-tune since there is a pilot. Duration can be programmed to be too long easily, etc... Just more ways to mess it up. They also sta
5.9's don't really have a HG issue, and the CR 5.9's have one of the worst OEM cam profiles ever... if not the worst. Then again, I've heard the 6.7 and 5.9 CR's use the same grind, thou the part numb
@pepsi71ocean ACS sent me an email after receiving my ECM to test under warranty. Their exact words were “we must advise you that having a tuner voids all warranty as per our policy.” However t
Sad but true case about aftermarket diesel tuning. I for 1 will never guarantee my work on a vehicle equipped with aftermarket programming. I've seen too many windowed engine blocks of newer CR diesels like the Power Joke 6.4 and 6.7, Cummins 5.9 and 6.7, and all models of the Dirtymax from broken connecting rods which I'm 110% convinced too far advanced injection timing caused.
