Spare tire bumper mounted carrier
- Replies 27
- Views 5.4k
Dieselfuture 6 posts
JAG1 5 posts
dave110 4 posts
trreed 3 posts
Mount it to the front bumper like the old Ford Camper Specials. It'll double as a winter cold front and the deer will just bounce off. Ideas..... I'm full of em
i had one, it worked great and could be flipped to sit in the bed or out of the bed. only thing is it lengthened the truck and you have to run a catch net in front of it if carrying small things (no
@JAG1 beat me to it! Might as well put it to good use.
Been thinking about this idea ever since I made my rear bumper. My spare tire has always been in the bed, it can't fit in original spot because of 5" exhaust and the tire holder rotted away long ago.
So I've been studying up on this idea and looking at different setups. Comp4x4 sells heavy duty hinge kit but currently closed due to moving. I thought about using bushing stock also but not set on that yet, then there is the trailer hub/spindle idea. Just wanted to see opinions, good, bad.... not only on what to use but the whole idea in general
Edit
Some ideas
https://www.google.com/search?q=bumper+tire+carrier&client=ms-android-verizon&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=2ahUKEwivrNTD9aXgAhUPKawKHYgpAGAQ_AUoAnoECA0QAg&biw=360&bih=560
