1/2 vulcan draw straw 3
- Replies 39
- Views 9.7k
01cummins4ever 9 posts
Mopar1973Man 5 posts
dripley 5 posts
JAG1 5 posts
I got the new check valve installed and cured that problem, holds 17 psi. at idle and 17 -18 psi at wot. next is to run this down past 1/8 tank and see if this draw straw performs better
There you go...
Since you have good fuel pressure when you first start it up, then later it goes low at idle after a run it sounds like symptoms of a clogged tank vent. That will create a vacuum in the tank at idle t
Is their an article on how to install a draw straw tube, I am deleting the in basket straw and installing it out side the basket, I know @Mopar1973Man had some post for one but cant seem to find anything
