- Replies 18
- Views 7.5k
Dieselfuture 4 posts
gipperkid 3 posts
Mopar1973Man 2 posts
Manimalmother 2 posts
Like @Mopar1973Man mentioned they are very similar, and like @trreed said there are some differences, main one is the exhaust on my turbo is still 3" where the s362 is 4" so the 4-inch one will flow b
There's more to it than just the dimensions of the wheels... The SXE line of turbos have a few manufacturing differences, namely a larger A/R compressor housing and J-blade turbine wheels give th
Without a compressor MAP and turbine flow its hard to do a side by side comparison Looks like a good turbo and hope it works well for you. Something to be said for modifying an hx35 or he
Wanting to change out turbo on my 99 auto , FASS ,edge ez w/ 75 injectors , 4" ex , BHAF , ATS trans w/ lock up control
Mainly because of mileage and its time to put a e- brake on and replace my cracked manifold
Trying to lower egts towing heavy ,
Want to stay turbo mt e-brake , and I`m happy with under 400 hp so no h40 downpipe
3 to chose are mod hx35 , k27 ,and s 200 gx-e built by Southeast Power Systems , sold by DAP
Lots of info on mod hx35 and k27 , but no info but seller`s on s200
The s200 is like the sxe 300`s in that its a newer design , its custom by SPS
Guy`s at DAP are recommending it , anyone ever run one ? Thinking of buying it
https://www.dieselautopower.com/s200gx-e-dodge-ram-upgrade-turbo-12769880001
Edited by dieseled
misspelling
