Oil and filter what do u guys run
I'm curious what you guys end up running for oil and filter personally I run amsoil 5-40 and amsoil filter now I'm changing to fleet guard filter LF16035
  • Replies 40
  • Views 10k
  • The Donaldson DBL7349 has better filtration and higher flow ratings than the Fleetgurad.    The DBL 7349 is 100% at 20µ, 98.7% at 15µ, and 59.97% at 7µ.   The Fleetguard LF16035 is
    Napa Gold Oil filter and either Napa oil 15w-40 or Chevron Delo 15w-40.
  • So am I. Since putting my old RV's back in and getting the MAP sensor replaced it is running with plenty of power. I have been avoiding a full WOT run until the HG is replaced. Might throw in a new se
What about Marine bhaf, aren't they the ones have steel Mash inside. I'm a bit nervous myself now, with 7x10 and 62/67/12, I may be pretty close to pushing limits off bhaf. Maybe a chunk of PVC or corrugated/ perforated tile inside the filter will prevent it from collapsing.
like I said I just started running an s&b style filter with a filter box and it's been fine
Donaldson and rotella. Every diesel on the farm I run rotella. I don't think you can go wrong with any combo listed here.
On 3/22/2019 at 7:06 PM, Miami Outlaw Diesel said:
HERE IS MY SET UP:
I ran one of them systems before on my old truck from amsoil nice pretty kit until issues mine on the filter base split so ya 3 gal of oil on the highway never again threw it in the trash in my area I wouldn't recommend it the filter close to the engine is better summer it's 90 winter last year  negative 40
Fleetguard oil filters.  Chevron Delo 15W-40...but I am tempted to try the new synthetic 5W-40 next oil change.
I also run a centrifugal oil filter...a Spinner II - bypass filter - that filters down to 1 micron.
How long miles have you running a spinner and what to you think about it?
Down to 1 micron... aren't you also catching some additives that are supposed to be good
I have been running the Spinner II for about 4 years....30K miles.
Additives are supposed to be liquid - not particulate -  so I don't worry about what it captures.
The main stuff captured would be very fine soot suspended in oil.
Last time I removed it - I weighed the material removed - and it was about 0.7 ounces  - accumulated over 8,000 miles since previous cleaning.
My installation can be seen here -  scroll through the posting and you can see installation photos - and a previous cleaning.
Edited by vineyardmh
Actually I'm thinking about switching to this filter after reading that thread  BD7317
If I didn't have my bmk 21 from Amsoil II'd probably try it. Can't be any worse than original factory filter.
Personally I think there is a reason they aren't spec'd for the ISB's in our trucks, and only for lower hp industrial ISB/QSB's. The size of the filter just isn't there to be really good at both full flow and bypass flow, and still get decent filter life.
There are plenty of guys running them, but not me.
I'd rather run the DBL7349 that is far better than OEM, and I know it's got enough media/flow. I just got 2 of them for $12.75/ea to the door on Amazon.
Edited by AH64ID
Would u think I would have issues with it
It's not likely, but it's not spec'd for the application so if you do then you are on your own.
Delo 400 15-40 wix and big filter.
I just resealed the vacumn pump. Not a drip and from nose to rear pinion. The rear pinion grrrr that's another story
Running delo 400 now for about 150k. Few thousand miles to break over 300.
I spent an hour with steam cleaner so grabbed a pic. So excited to not be leaking
last year around this time I resealed the tappet cover and the vacuum pump the tappet cover seal was cracked and had about a 1/8 in gaps I was leaking about a gallon a week
Damn. I was only leaking a few quarts.
Assuming the discussion was about whether or not the Spinner II is sized for our ISB engines - the answer is yes - it is, if you get the proper model (Model 25).  There are various sized Centrifugal bypass filters.  Big rigs might have a flow rate of 2 to 4 gallons per minute, and they have bigger bowls and can store more particulates so that one can go longer without removing and cleaning it.  Some fleets are going to 150K to 250K between complete oil changes; they rely on oil sampling to verify the oil still has adequate life to continue use.
The Spinner II Model 25 is rated suitable for all diesel pickup trucks, and it has 0.8 GPM - which is a trivial 'tap' from the main oil flow through the regular filter - and to the engine.  I clean the bowl about every 15K miles - and the bowl could probably go to 150K miles before needing cleaning.
BTW - I have a second unit that I am going to sell...with most of the mounting hardware and a base plate.  The Spinner II Model 25 lists for $452, and I am going to list mine for $250.
We were talking about the BD7317 that silverdodge asked about.
Spinners are great filters. Just a lot of work to fit them on these smaller trucks, even the small ones built just for the ISB. Fleetguard also makes one.
