- Replies 25
- Views 6k
Rotax3006 7 posts
Mopar1973Man 6 posts
Evan 6 posts
WiscoRedkneck 1 post
I switched out my original injectors at around 300k, or thier abouts. With new RV 275’s along with a quad xzt+. at the same time. Now have 321k, and completely happy with the performance. The xzt gene
I'm running the same as @01cummins4ever but with an Edge EZ and use the truck 90% of the time for towing up to 9k pound trailers. I really like the boost of power with out overwhelming the drive trai
I just switched to RV275's about 6,000 miles ago (303,000 miles on the OEM injectors). They perform well for me. I have never heard of any negative comments about the RV275 injectors. I
Hi guys
So I think its time for some new injectors, truck has a pretty decent knock than sounds like all the injector knock videos on you tube. The stock ones have 253000 miles on them so I'm sure the pop pressure is pretty low. From my reading on here it sounds like maybe 100-150k mile per set give or take. So my question is. With a mostly stock truck would you guys recommend RV 275s or the DAP 7V.008 50 HP set or something completely different. Some day I would like to add some HP but nothing too crazy for the time being anyway. They are pretty similar in cost so looking for advise/experiences for other users.
98.5 Standard Cab with lots of dents and rust.
