- Replies 29
- Views 4.4k
Unreal Summit 7 posts
Mopar1973Man 6 posts
Rotax3006 4 posts
dripley 3 posts
Popular Days
If you do decide to put a bottle on it to catch any dripping, just make sure it vents. If it is sealed up tight, you will prevent the crankcase from venting and can cause other damage and likely more
Gets even worse vacuum leaks
The two times over the life of my truck that I noticed the breather tube was messier and leaked more oil than normal, I had a vacuum leak. Neither time was the vacuum leak large enough to noticeably
I know its been asked so forgive me, but I have done the Moparman mod and before I took my truck to the body shop I got maybe one drip of oil from the tube after 4 months with the mod. However after I got my truck back it drips after every trip. Just a small drop. I did the blow by test and it Is perfect. Is this normal or something I need to look into? Thanks guys!
