- Replies 25
- Views 6.9k
Mopar1973Man 6 posts
AH64ID 5 posts
Evan 5 posts
Bullet 3 posts
I looked at a few other brands of studs that were cheaper than ARP's...can't remember the names of them. But when I researched them myself I found several complaints of snapping while being torqued.
Headstuds are kinda like insurance against a blown head gasket if you're gonna run higher boost pressures. Headstuds are needed when running boost pressures of 45-50 lbs or more. The stock headbolts
Also used for longevity. Like in my case I don't want to do head gaskets every 300k miles. The tinsel strength of the ARP 425 should keep the head from curling on the end over time. Where normal head
Has anybody used or heard of Black Market Performances head studs? They’re about $150 less and a ARP set and the same tensile strength. Was curious if anybody had used them
