Uneducated second gen owner in need of help
- Replies 68
- Views 12.5k
Mopar1973Man 14 posts
Kane4sythe 12 posts
dripley 8 posts
Silverdodge 8 posts
There is quite a bit of things that need attention first that are in the article section. All mostly for reliability and the long haul. I love having two of these trucks that run so sweet by my hand a
We are a bunch of old farts, at least in our way of thinking and most of us run stock size wheels and tires
Save your money for parts you'll be needing like a new dash, heatercore, injectors, VP44, and on and on.
I have asked questions on here before, but now as I have some money saved up I am ready to spend a little on my truck and have a question to ask, that will most likely lead to 100 other questions. To start off with, I have a 2001 24 valve that just hit 194000 miles. I bought the truck completely stock performance wise other than an edge comp box, and have done nothing to it since. The only issues with the truck that I know of is the transmission pan seems to have a leak, which I believe I can easily fix by replacing the gasket, and I have a broken sway at bushing, but I have asked about this before and some people on here have said that they completely removed their sway bar and have no issues and as I have been driving the truck for a few months with a broken bushing I am not very concerned about it, unless you guys think I should be. So enough with all the back ground, my main thing is: I’m tired of running these stock wheels, I want something a little different. I was think about going with 20x12 and possibly 305 50 tires. What I don’t want to do is anything to the truck. Is this an ok move or do you guys believe this is a completely stupid move to put these wheels and tires on my truck with 0 modifications to the truck and stock suspension and steering. I don’t want to do something that will ruin my truck but would also love to put these on my truck. If there is something that needs to be done in order to put these on my truck, what would you guys recommend doing first?
Thank you in advance, and recommendations and comments are much appreciated, and please keep in mind I have no experience with any sort of mechanics so this is all a learning experience, so if you do reply to me, expect many questions ?
