- Replies 12
- Views 2.3k
Mopar1973Man 3 posts
WesHawkins 2 posts
IBMobile 1 post
Marcus2000monster 1 post
From the FSM, how to check turbo charger shaft for play.. (3) Visually inspect the turbocharger compressor housing for an impeller rubbing condition (Fig. 25). Replace the turbocharger if
All turbos have some play when they are stationary. To correctly assess for excessive side to side movement, you would need to have one hand on the compressor wheel and the other hand on the turbine
How many miles? If you replace it can I have it?
Return home from our trip up to McCall, Idaho without a hitch after installing the new Timbo APPS at the RV park. Started doing a service on the truck here at home and noticed a little side play in the turbo shaft. Don’t know how much play but it’s enough I can feel it. I’m thinking I should replace it now before it gets worse.
Anyone recommend a good stock replacement turbo? The truck is a 2000. Mostly stock. I’ve added Edge Easy box, FASS lift pump, a 4 inch exhaust turbo to Tail pipe and a PakBrake exhaust brake system. Truck has 110,000 miles on it.
I don’t want a rebuilt turbo, I prefer new without breaking the bank.
Appreciate any opinions
Thanks, Wes.
