Engine noise (revisited)
- Replies 27
- Views 5.9k
dripley 7 posts
JAG1 6 posts
Mopar1973Man 3 posts
98whitelightnin 3 posts
Put hose on it..... could'a used it for a shop vac. Sorry about that one... at least it not a joke about sucking feathers or sumpin.
I agree, that sounds like a healthy vp truck to me. @dripley here is a pic of my old roommates 2001 truck after he blew the head gasket. His truck had 450k miles on it and he never ran an air fi
Did you use the K&N for target practice? I hear it don't matter if it got holes or not....
A little while ago i posted about an engine knocking/pulsating sound. I changed injectors and adjusted valves and the noise is still there. The engine is definitely more rattly since I first got the truck 6 years ago.
I also got an oil test and everything came back ABOVE average. Has the same amount of blowby as it always had at operating temp.
Where do I go from here after doing all of this? Is there an engine condition that wouldn't show up on an oil test? Can an injection pump thats going out cause noises? Where do I go from here?
Video below to hear what you guys think.
