- Replies 32
- Views 8.4k
Mopar1973Man 13 posts
NIsaacs 7 posts
AH64ID 5 posts
dripley 3 posts
Big difference in repair parts and upgrade parts. In my younger years I would get cheap parts store parts and they were junk, but I was broke and had time to replace them... sometimes on
I really wanted to laugh and like this one. The last statement is very true and I have experienced that. Most of cheap parts I have used are the readily accessable ones and easy to swap, but not alway
In speaking to those 3 specific items it's due to the poor reputation of non-OEM parts. With all the forums we have the ability to learn from others experiences, good and bad. Those exper
I want to bring up something that i think is rather weird. Majority of people here are quick to make changes to there truck and ditch OEM stuff. For the 2nd Gen 24V the OEM lift pump is removed and upgraded to FASS, AirDog or mechanical pump. Stock OEM injectors pull out and aftermarket oversized injectors installed. Then the Factory ECM tune is ditched for Quadzilla, Smarty, Edge, etc.
Why in the heck does any one want to hold so dearly to a thermostat, water pump or a fan clutch that MUST be OEM?
First off if you do your research Moprar and Cummins don't make very many parts. Like the last blow up over a thermostat. There is only a small handful of companies making thermostats. Again Mopar and Cummins don't manufacture any thermostats, fan clutches, or water pumps.
The other thing is comments of all the failures on forums. Wow. Sure everyone is quick to complain about a failure of a part. But... There is lots of different things that could of gone wrong. Improper installation, defective part, abusing the vehicle, radiator plugged up, etc. Then rarely if at all does anyone say anything about great results with a aftermarket parts. So that is a very skewed method picking parts.
My point is Mopar and Cummins is NOT doing any research to improve parts for our trucks they are done. There is entire aftermarket world where companies are actually improving parts and products. What is there just the handful of parts that MUST be OEM? I've got no clue...
I've watch as @Me78569 use OEM Dana Ball joints which end up failing early too. I watch people do this all the time thinking that the same parts are still there from back in 1998.5 to 2002. Nope those parts are long gone and someone else is making the replacement parts for Mopar and Cummins. Kind of like the original fuel pickup basket of the 1998.5 to 2002 that no longer produced period.
The only thing I want to point out before jumping into Cummins or Mopar for OEM parts. First do a bit of research. First off is the old part going to be the same part manufacturer? Most likely not. Second find out who is manufacturing said part now. Pretty sure you'll find out you can have the very same part but a reasonable price from the manufacturer that is supplying Mopar or Cummins. You don't have to buy the logo on the box.
Then there is the entire aftermarket world of parts where other companies are making better parts and supplies for our trucks. Kind of like saying you want a OEM 47RE transmission which everyone here knows was a weak transmission won't hold the power. That where the aftermarket world comes in and making thing better with heavy duty parts. If OEM is so great I offer anyone to return there truck back to OEM let's go back to the OEM lift pump on the block or the OEM lift pump in the tank... I'm sure that won't last very long at all. Why even ask for OEM anything knowing that 99% of all parts today have been improved over the OEM of 1998.5 to 2002...
Some people forget... I just don't work on my own truck but tons of vehicles. I work on Dodge's, Ram's, Chevy's, Ford's, etc. Now I will admit there is some parts I've seen low service rates. I'm not going to beat anyone up over it I just use something that works better. Very very rare do I ever go to a dealer for parts this is plain foolish.
Like there are sometimes that OEM is the only choice. I did a A/C job on a Subaru few years back and it was a hybrid car (6 cylinder) this made the A/C parts rather rare. I needed the pressure switch on the accumulator. Hunted all over the place for that switch come to find out its a dealer only item. What was worse was you had to buy it with the accumulator at the price of $520 dollars. Just because it came from Subaru dealer it was priced extremely high. I had no other choice. If there was a aftermarket part I would of jump in a heart beat and left Subaru dealer in a hurry.
My job to all you is to help you fix your truck and help you get parts that are reasonable in price and good service life. I really do have a problem when people are push into dealer parts and prices because it not always the best parts either. Again why do we pull all the OEM stuff and replace it with aftermarket stuff?
