EGT Probe Installation
- Replies 15
- Views 7.2k
Leaky88 3 posts
Bullet 3 posts
Mopar1973Man 2 posts
Evan 2 posts
I did mine without removing the turbo. Back side, Midway up the collector. I drilled with the truck running. Used axle grease on the bit to help make the chips stick. Drilled in small i
I have a modular exhaust manifold now that was pre-drilled and tapped...but way back in the day I drilled and tapped my stock manifold successfully. I drilled and tapped the back pipe of the collecto
This what I have...I think it's from geno's?
Hi,
I want install Isspro pyrometer gauge. Lots of well meant advise on YouTube etc., with some contradiction.
Questions I have concerning probe placement are:
1) Which is it, the left or right side of the collector, and where? Halfway up, the middle, or top.
2) Do I Drill and Tap in place, or remove Turbo first. Despite the Dollar Store magnet cleanings I’ve watched,
doing it in place has me looking up the cost of a replacement Turbo. Of course, removing the Turbo first will have its own challenges given age of fasteners.
Any advice or experiences would be appreciated.
Thanks
Leaky
