Newbie, changed fuel filter today, have questions
- Replies 14
- Views 2.7k
Doubletrouble 4 posts
Mopar1973Man 2 posts
JAG1 2 posts
hdpwipmonkey 2 posts
Out of the two brands of fuel pressure gauges I own and have tested for accuracy, the Isspro is the closest to actual pressures. my excavator who was in business for over 40 yrs owned lots of equipme
First thing I did when I bought my truck is put in a new lift pump. I went with a FASS 165 at the recommendation of a friend. So far its been ok. Had an issue with the pressure fluctuating at first
I belueve he just has the FASS ddrp. Hence the small strainer.
I am a newbie to Cummins diesel trucks so bare with me and my questions.
I changed my fuel filter today, once the old filter was out I noticed debris in the bottom on the filter housing so I cleaned that out best I could. I had to drain the housing so it took a few key cycles to prime again but she did restart.
While doing this I noticed another inline filter before the LP that I'm sure is not factory. See pics below, before and after cleaning out the debris, last one you should be able to see the inline filter down near the frame.
Also, there is what seems like a larger line from the LP to the filter housing. Is this just an adapter or is it what is considered a "big line kit"? I'll post a pic to hopefully show this blue line I'm talking about. Thanks in advance for any replies.
