Want a little more power
- Replies 21
- Views 7.3k
Blueox01 4 posts
dieselautopower 3 posts
Dieselfuture 3 posts
Royal Squire 2 posts
K27 is 60mm compressor, but it is shorter and smaller and moves LESS air than the s300G 57mm. K27 is similar to 35/40 hybrid, and max 75-100HP injector with an adrenaline. 57mm s300GXE is
Edge EZ does boost fooling so adding a Qudzilla fooler will not get you any gains. A boost elbow would help a little. More fuel and custom tuning with an adrenaline would be the next upgr
You're using an Edge EZ and RV275 like I have. I'm using an adjustable boost controller and have it turned up to 30PSI of boost. I got out of China for $5. Some other members ordered them but I t
Looking to get a little more power, probably all I need is a little more boost. Anyone know anything about Turbosmart wastegates? Another option was a boost fooler but heard mixed reviews as how much they actually do. Also was looking at upgrading Turbo, Borg Warner makes a drop in K27 that it says has better low/mid range response. Not sure I want to upgrade to more performance electronics like Quadzilla or Edge. Any suggestions?
