Move ECM to firewall or inside cab?
- Replies 15
- Views 7.3k
Mopar1973Man 3 posts
AH64ID 2 posts
kzimmer 2 posts
wil440 2 posts
Popular Days
Leave it on the block nothing gained by moving.
Yes. A few feet of wire added can't hurt anything. The only thing that can hurt it is a bad splice/termination or improper shielding causing noise. Agreed.
I think it's a great idea. The only reason it is where it is, is because Cummins supplied the motor as a running package. No one in their right mind would design it like that on purpose as a whole. Th
Can anyone think of a reason why I shouldn’t move my ecm to inside the cab or the firewall? My engine harness is out of the truck getting improvements and I have a second wiring harness that I was using to help diagnose my ecm issue. I realized I could use the second harness to extend the length of my current one. There is room on the firewall under the brake master cylinder or in the cab under passenger dash. Only alterations besides splicing I can think of is I would have to make more twisted pairs of the water in fuel(not used) and oil pressure sensor wires since they are the shortest and exit right by ecm. There are also 2 shielded pairs (vp44 and Cummins bus). The Cummins bus (which the Quad uses) l wouldn’t have to extend. It would just end up in a different place. For the vp44 pair, I could just wire both harnesses wires end to end, and run one shield power wire to both shields. Only worry is if ecm is expecting a resistance range on that wire, since increasing the shield length would make the resistance go up. Ecm on the engine is obviously not the best place.
