- Replies 32
- Views 10k
BDK 7 posts
AH64ID 5 posts
Mopar1973Man 4 posts
Evan 4 posts
Popular Days
Here are a couple pictures. The second picture is where I have removed the actuator assembly from the axle (and removed the vacuum motor) the switch is st
If it were mine I'd install non cad axle shaft and plug vacumn lines. My jeep has the same cad setup. I welded the collar in place permanently locking it. I also have a noncad axle with l
I've got a CAD axle in my 1996 Dodge Ram 1500 and absolutely hate the dang thing. Sometimes it will lock quickly and then fight to get it unlocked for +10 miles. I've replaced the vacuum motor, fork s
I have a 2001 (2nd gen. Cummins) 2500 4x4 SRW with the CAD system on the front Axle and needed a few questions answered. 1st post BTW and just joined...
The PO has disconnected the switch for the 4x4 at the CAD (the connector that plugs into the CAD). The switch/sender is still connected to the CAD but there is no connector anywhere NEAR this. I've looked up and down and it just is not there, so my question is, where does the connector plug into that runs to the CAD (i.e. as in where on WHICH wiring harness is it Tee-d off of)? Can a replacement be ordered and then just plug into the wiring harness on one end and the CAD switch on the other? Any pics showing both ends would be VERY helpful.
BDK
