Sucks on the highway
- Replies 11
- Views 2.8k
420Wd 3 posts
Doubletrouble 2 posts
kzimmer 1 post
NIsaacs 1 post
Popular Days
I think more information would be helpful. Is your truck automatic or manual trans? Gear ratio, tire size and so on. It will help diagnose the issue. You should put this info in your signature for fut
You're reading a quote in @Me78569's signature. Not directed towards you.
My 1999 24 valve at highways speeds seems to have no throttle response. Up hills truck can drop a bit below speed and when I give fuel nothing .. hit flat ground and away it goes ..
truck pulls and shifts flawlessly at non highway speeds .. 23lbs boost, no lower then 10psi fuel, any ideas? It’s embarrassingly be able to be put pulled by a gasser you hill on the highway
Check engine light not on
