1999 3500 Cummins won't crank over
- Replies 37
- Views 8.7k
pepsi71ocean 12 posts
dave110 5 posts
IBMobile 5 posts
Dieselfuture 4 posts
@pepsi71ocean, are saying that when you turn the ignition switch to the start position the starter does not crank and the lift pump does not run? If this is so, then maybe you disturbed a wiring harn
Back when I was seriously contemplating a manual swap and reading all the threads I could on it I remember some guys getting away with the Auto PCM and either jumping or grounding a wire on the NSS t
If you jump terminals 30 and 87 at the relay, does the starter engage? If so, then your starter is fine. If not, you're looking for something on that circuit. Neutral safety switch would be out of the
Hey guys, so ive done several good wiring go overs and I can't get my truck to start.
I suspect now it could be the neutral safety switch, but I'm not sure at this point since the reverse lights come on when the truck is in reverse.
I'm out of ideas here.
EDIT:
I pulled codes with the scan gauge and got po602, and po1689
Also can anyone tell me what this plug is for?
I believe there is a purple and white wire on it. I think it's the CCD, but I don't remember now.
Edited by pepsi71ocean
