Diesel fuel
Just curious to see what your diesel looks like. Here is what I get around quad cities Iowa, most of it is labeled 5-20% bio. It sure looks like gasoline to me, but then again I don't stare at it every time I fill up. Is this normal looking or :think:IMG_20201022_182529.jpg.28819e488fbca5d96da50d38565c8fe2.jpg
  • Replies 16
  • Views 4.6k
  • Weird. Mines red            Seriously though, I've never poured it in a jar to look but it doesn't look like that here. Has a green tint to it. It's not bio though. I hav
  • Are you sure that's not a urine sample?    The diesel here is light yellow to clear.
Weird. Mines red :sofa:
Seriously though, I've never poured it in a jar to look but it doesn't look like that here. Has a green tint to it. It's not bio though. I have no experience with that.
Could also pass for a Miller Lite. Oh, wait. You already said urine sample.
37 minutes ago, Towrigdually said:
Mine looks blue down in Oklahoma,
You sure it's not because of 2 stroke.
Guess I should have let the bobbles settle out before I took the picture :lmao:
Round about 10pm Saturday, just make sure you grab the right bottle. Too many choices can be a bad thing.
Pretty sure, been using some Lucas injector stuff I got for free. Haven’t used 2-stroke in about 3 months.
Little info...
Higher the cetane the shorter the carbon chains, the lower the BTU's per gallon and then the weight per gallon is less. Bio diesel is typically lighter per gallon and typically 45 to 50 cetane. Like here I'm already running winterized #2 diesel and it green tint in color. Then since about September I had to back down timing on the Quadzilla. 20° to 21° at 2k RPM. When I get back to summer fuel which is 40 to 43 cetane I can jump back to my high timing of the summer 23° works good at 2k RPMs.
Petroleum Diesel
  • #1 Diesel - 137k BTU's
  • #2 Diesel - 139k BTU's (summer fuel)
  • #3 Diesel - 141k BTU's
  • #4 Diesel - 145k BTU's
  • #5 Diesel - 148k BTU's
  • #6 Diesel - 152k BTU's
Biodiesel
  • B2 - 138k BTU's (1% loss)
  • B20 - 134k BTU's (4% loss)
  • B100 - 118k BTUs. (16% loss)
Funny how all bio fuels are always LESS energy per gallon... That fact will never change being that high cetane ALWAYS means lower BTU's there is no way around that fact.
cetane-btu3.jpg.718cdb12cd43873ccaa0be5d
 Light green is winterized fuels up here and dark green is the summer fuel.
As from ASTM Labs...
Quote
There is no benefit to using a higher cetane number fuel than is specified by the engine's manufacturer. The ASTM Standard Specification for Diesel Fuel Oils (D-975) states, "The cetane number requirements depend on engine design, size, nature of speed and load variations, and on starting and atmospheric conditions. Increase in cetane number over values actually required does not materially improve engine performance. Accordingly, the cetane number specified should be as low as possible to insure maximum fuel availability." This quote underscores the importance of matching engine cetane requirements with fuel cetane number!!!
5 hours ago, Dieselfuture said:
Where's @dripley I want to know what he burns in his fryer :whistle2: oh no I didn't :sofa:
Been wondering too. Hope he's not in the fryer. Kinda miss his help when we're de-railing a thread  :lmao:
 Ours here in N.W. Ohio has turned green recently. Winter blend I assume. I still have a tank full of red outside for farm equipment. Going to have to treat that soon to avoid gelling and moisture in it.
On 10/24/2020 at 2:44 AM, JAG1 said:
I wonder too where he is. I hope he's okay. :pray:
:sofa:
