24 valve reman pump issues
- Replies 20
- Views 6.4k
Cumminsguy5.9 5 posts
JAG1 3 posts
Me78569 3 posts
Tractorman 2 posts
I am very glad you told us about this as I know it will help others to always ask where the rebuilt injection pump comes from before you pay. If they do not want to tell you then they don't need your
The signal it's looking for is a small current blip in the injection solenoid's current when the plunger moves. A solenoid has a 'dead time' from when the current is first switched on until the plunge
Metering solenoid is physically on the injection pump in the middle of the distributor. Those two wires go back to the PSG on top of the VP44. This means there is a wiring or circuit problem between t
What’s going on guys? So as per my last topic the vp44 was my issue for whatever reason my edge wasn’t allowing my ecu to throw any dtc after figuring that out I found the p1628 or whatever the vp death code is can’t remember off the top of my head. Alright, replaced the pump with a reman vp44 from xdp and new fuel filters. Got the truck primed and she took off. Ran for about a day or so and then boom no fuel to the injectors again. Even though I do not like doing it I tried anyways I gave it a breath of ether and cracked the injector lines and still no fuel. Okay fine play hard. Towed the truck home and figured I’d call xdp and ask for my warranty (mind you this pump is only 2 days running on this truck give or take a half day and no I left my wire tap off for this very reason just incase). Anyways talked to xdp and gave them my new code it was throwing which is p0252 fuel metering control valve if I’m not mistaken. (Bad pump?) No to them that means dirt in the pump so I pulled my line into the pump and ran it for I don’t know 10-15 seconds into a 5 gallon bucket and found no dirt. Pulled filters and there was some dirt not much to make me worry though . Maybe I am mistaken but to me that means that 1 filters are working and 2 there probably isn’t dirt in the pump it’s self. Xdp wants to play games and I’m pretty irritated I want to make sure that I’m not in the wrong here guys. P.s. they want me to send the pump out pay shipping to send it to a testing shop and they are two weeks out and if I need a new pump xdp is also two weeks out.
-kindest regards Eric
