Swapping a nv 4500 for a 5600
- Replies 26
- Views 17.2k
Mopar1973Man 9 posts
jlwelding 4 posts
AH64ID 3 posts
dripley 3 posts
The over fill on the 5600 was to get more oil back to the 6th gear bearing as have always understood. Had nothing to do with the Sychromesh being thin. At least as far as I have read. Last time I chec
Syncromesh is NOT supposed to meet the GL-4 rating, so that’s a good thing. Don’t try to make it meet a spec it’s not designed for. Not to mention GL-4 isn’t a thickness spec and there are G
No, power has nothing to do with syncro's. The clutch is released (no power) when you shift. Syncro's can be bad (poor quality) from the get go, bad shifting habits, the wrong oil type or
What is involved in replacing the nv4500 with the 6 speed? I cant keep a 5 speed evidently, I believe they just skimp by on parts or something. The only other thing I can think of is I'm running the amsoil synthetic.
