- Replies 22
- Views 4.4k
JAG1 6 posts
AH64ID 4 posts
Tractorman 4 posts
Mopar1973Man 3 posts
Popular Days
If this is with an empty truck you have way too much air in them. 5-10 psi is enough, that is what I run in my Ford and '91 Dodge. I do not run bags on my '01. I also never add air when I load it up.
Weight is weight... Doesn't matter put it on the scale and weigh it out. Weigh is on everything ground, tires, suspension, frame etc.
Way too much air in the bags. Drop them to 5 psi at that weight. With your stock tires you shouldn’t ever need more than 50-60 psi, and that will be with tires nearing 100% load.
Hello everyone, want to wish everyone a happy Thanksgiving especially to MoparMan, IBMobile and W-T for adding so much education to this site. Special mention to Dripley who always provides Chicken. Sorry
, I know the rules...... couldn't help it.
Anyhow about the overloads, what is the best way to get the overloads back inaction as I have Air Bags on the truck that does not let the overloads help and the air bags sometimes bounce the truck side to side like crazy. I'm thinking bump stop extensions , but don't see how they would last holding on for dear life with just one bolt holding each one. Thanks for any thoughts
