- Replies 22
- Views 4.1k
Mopar1973Man 6 posts
JAG1 4 posts
Dieselfuture 3 posts
LorenS 3 posts
It would be interesting to see a photo of that fuse after that event occurred. What you have described is indicative of a poor electrical connection at a precise location, the fuse stud. It would al
Just put a denso in and forget about rebuilding your Bosch. You can even put a slightly higher amp 160? one from Durango I believe. I rebuild my Bosch it's not too bad. You'll need more than just
My second Original alternator just shorted out again. First one was the original ND, original to the truck at 222,000 roughly. Six months later an original Bosch from the other truck with about 30,000
Hey everyone, I hope all is well.
I currently have a Bosch alternator and even with the WT mod I am experiencing high AC ripple. I plan to replace the alternator and am wondering if I can replace it with a Denso unit as they seem to be more plentiful than the Bosch units.
I also plan to keep my stock alternator and rebuild it with a new rectifier, bearings and brushes. Has anyone rebuilt their Bosch alternator? I'm curious if it is easy to do. I have found a replacement rectifier online so they are available.
Thanks and I hope everyone has a happy Thanksgiving.
L8tr
d
