Head Stud Install Question
- Replies 21
- Views 11.6k
Mopar1973Man 4 posts
AH64ID 4 posts
dripley 4 posts
JHFIII 2 posts
Do not loosen all the bolts first. Everything I have seen is a one bolt at a time. If you pull all the bolts you might as well do a head job. your seal on the head gasket will be compromised.
When I did mine I did one at at time in 3 phases to 105 lbs. When they were all done I went back around in 3 passes with about 30 minutes between at 115 then 125. I then turned the block heater on for
Kind of like my Cummins. Same 3 phase torque method. Final on my ARP425 studs where 125 Foot/Pounds as well. The only difference I never did a second warm torque at all. According ARP themselves a war
I plan to install my new injectors soon and was wondering if that would be a good time to install head studs. Can a guy loosen all 26 bolts, then install the studs 'finger tight' one at a time without worrying about the head shifting or otherwise affecting the head gasket?
Or, is it recommended to completely remove the cylinder head and install new gasket when installing studs?
