- Replies 14
- Views 2.9k
Mopar1973Man 4 posts
Alexio Auditore 3 posts
Tractorman 2 posts
Towrigdually 1 post
Popular Days
This is just a personal opinion, but I think the power steering system on our generation of Dodge Rams is pushed to the limits from an engineering point of view. Years ago when I would design hydraul
I'm sure most of us are experiencing cold weather one way or another, and so I'm curious if you have had any problems related to steering/ hydroboost issues.
Whenever it gets to the low teens or single digit temps, I start the truck in the morning, and fires right up, and you can hear and feel loud humming vibrations in the cab. It gets loud if I touch the brakes or turn the steering wheel, and you can definitely feel it vibrating through both. I figure something maybe with the hydroboost. It had been doing this for years, and I thought maybe a new steering pump would fix it, but it didn't.(needed to be replaced anyway.) Anyone else experiencing this issue?
Going to the steering issue:
I replaced my steering pump last spring with the one from genos. From day one, it felt under powered....but I thought maybe it would get better with time, maybe a little air in the system, despite a thorough bleeding and following the steps to get the air out.(also new lines to and from the the hydroboost. Even disconnected the return line from the steering box to get ALL the old fluid out.)
Sitting in my truck now, operating temp and all, I cannot physically turn the steering wheel while the truck is standing in place, the tires won't budge.(265 75r 16 Michelin Defenders) I have to be moving ever so slightly to get some assistance to turn the wheels (increasing rpms does nothing to help either.)
Does this sound right? this issue isn't because of cold weather, but it probably makes it worse.
The pump has Redline full synthetic powersteering fluid in it.
Here's the pump.
https://www.genosgarage.com/product/BORG-800328/power-steering-pump
