- Replies 47
- Views 7.5k
hdpwipmonkey 17 posts
wil440 10 posts
Mopar1973Man 8 posts
IBMobile 4 posts
When the brake peddle is depressed pin #C1/9 of the antilock brake controller, pin #24 of the ECM, and pin #C3/24 of the PCM all ground through the brake light switch to grounds G200 at the left cowl,
As I said in my original last post on my left turn/ wiper problem I can be accelerating harder in L/U after cleaning up the G100 before the lockup clutch starts to chatter/slip, nothing else has chang
and if it isn't your problem at least you'll have ticked off a ground that is very prone to corrosion
Over the last couple of weeks I noticed my TC was acting weird. When its engaged over 45mph and I hit the brakes the TC disengages like its supposed to but then immediately reengages as soon as I let off the brake and its a noticeable reengagement. It has never done that before. It would always stay off unless I got back on the gas pedal. I scanned for codes and it had 2 codes. One for APPS low voltage and one for charging system low. So I bought a new Timbo APPS and installed it today. The TC is still acting the same. I checked the alternator and it is charging normally. I did notice that the AC voltage is up though. When I first did the WT mod the AC noise was at almost nothing but now its at .05 VAC. I may have to replace the alternator again. This ones only about 2 years old. Anything else you can think of that would cause the TC to act like this?
I also have another question. If I go with a Nations alternator (I want a better quality alternator) will I have to get a different breaker. I currently have a 150 Amp breaker installed but the Nations Alternator is 180 Amp. I'm guessing the 150 amp breaker will be good as the truck shouldn't draw over the 136 Amps that the OEM alternator is rated for unless something is wrong or I add something that would draw more power.
